How do I fix this mistake?
Forum topic by Sailor posted 04-16-2013 09:00 PM 1263 views 0 times favorited 13 replies Add to Favorites Watch
View Sailor's profile
Sailor
543 posts in 3462 days
04-16-2013 09:00 PM
So, I made a large built in for my sister with 4 small cabinet doors in it. I made the doors from MDF sized for a 1/4” overlay all the way around instead of 1/2” overlay like I have in the past. I was thinking I could get some 1/4” overlay concealed hinges but as it turns out my local shops only have 1/2” overlay concealed hinges.
I have tried adjusting them in closer together all the way but it’s not close enough…... still a gap between the two doors that were meant for a 1/4” overlay. So basically there is a 1/2” gap between my two doors where they meet when closed…...
Is there any way I can make the 1/2” hinges work? Maybe by redrilling the holes in the door a little nearer the edges? I would build more doors but the entire thing has already been painted…..
I know I could just use regular hinges on the face frames but my sister was really wanting the concealed hinge look. Any ideas?
-- Dothan, Alabama Check out my woodworking blog! http://woodworkingtrip.blogspot.com/ Also my Youtube Channel's Facebook page https://www.facebook.com/SailingAndSuch
13 replies so far
View Marcus's profile
Marcus
1163 posts in 2216 days
#1 posted 04-16-2013 09:06 PM
maybe add 1/4” trim all the way around the doors? might give a little design element?
View Mark Smith's profile
Mark Smith
509 posts in 2237 days
#2 posted 04-16-2013 09:07 PM
How about gluing a 1/4” strip of something to the doors? Or if a quarter inch is too small, cut another few inches off the doors and then glue something bigger on. Kind of hard to tell without seeing a picture of what you’re talking about.
117328 posts in 3774 days
#3 posted 04-16-2013 09:08 PM
You could add some quirk beading to your doors.
http://www.finewoodworking.com/woodworking-plans/video/two-ways-to-make-cock-beading.aspx
Edit
Wow three people commented while I was typing
View DS's profile
DS
3030 posts in 2617 days
#4 posted 04-16-2013 09:13 PM
+1 to James…
If this is a two piece euro hinge, they are sold with different baseplates, 0mm 3mm, to 9mm.
I’m pretty sure a half cranked hinge with a 3mm plate will give you 1/4” overlay.
Otherwise, a 1/4’ spacer under your mounting plate might just be the ticket.
404 - Not Found
2544 posts in 3166 days
#5 posted 04-16-2013 09:16 PM
James nailed it
Sailor
#6 posted 04-17-2013 01:29 AM
Not sure what brand they are. They came out of a bin at a whole seller so there is no packaging or anything. I don’t think they have anything will do a 1/4” overlay. I guess I can just order some 1/4” overlay or just go with a surface mount hinge….
Thanks for all your suggestions!
Sailor
#7 posted 04-17-2013 12:12 PM
WOw thanks for the offer James! I think I should be able to locate some, but if not I may look to you. Thank you very much for the offer and you time.
View MrRon's profile
MrRon
5189 posts in 3440 days
#8 posted 04-17-2013 06:35 PM
Since they are MDF, why not just cut some new doors. The material is cheap enough and a lot less fuss than looking for different hinges or adding trim to the edges. If it were good hardwood or veneered plywood, that would be different.
View dbray45's profile
dbray45
3320 posts in 2973 days
#9 posted 04-17-2013 06:53 PM
Great minds – read the problem – first idea was the same as Jim
-- David in Damascus, MD
View Charlie's profile
Charlie
1100 posts in 2483 days
#10 posted 04-17-2013 07:29 PM
If these are euro hinges you need a 6mm plate to make a 1/2” overly into a 1/4” overlay. Then you’re done.
View Richard Miller's profile
Richard Miller
139 posts in 2167 days
#11 posted 04-17-2013 07:41 PM
Blum hinges have 1/4” mounting plates.
-- Dick F,Burg Iowa
View HorizontalMike's profile
HorizontalMike
7770 posts in 3111 days
#12 posted 04-17-2013 07:42 PM
@a1Jim,
Thanks for the video link. That actually looks doable for someone like me who has built just a handful of furniture pieces. I honestly think I will try something like this on one of my ‘next’ projects, once I decide what that will be…
View DS's profile
DS
#13 posted 04-17-2013 07:49 PM
I switched to frameless construction years ago and never looked back.
I have a bucket full of old hinges (maybe 40 pairs of new old-stock) that have been collecting dust for a very long time.
If any of those will make 1/4” overlay you are welcome to them. (I’ll have to check this evening when I get home.)
