Leveling Feet
Forum topic by BrandonR posted 04-16-2013 12:37 PM 1271 views 0 times favorited 5 replies Add to Favorites Watch
View BrandonR's profile
BrandonR
64 posts in 2259 days
04-16-2013 12:37 PM
I just built an outdoor cedar table and two benches to go along with it. The legs are all 4×4s…..
I cut each leg exactly the same…. I know though there are tons of variables! I pocket holed the skirts to the legs, so I know some of the skirts could be just a cm high or such pulling that leg up by a hair….
The table is solid and level. When you sit on the benches they are steady, but when not sitting on them you can rock them ever so slightly…. I can’t tell which leg is short or long. When you tilt it one way one leg looks 1/32 of an inch short, when tilt it the opposite way it is the opposite leg that looks just a tad bit short….
Any advice on how to level these out. I unfortunately don’t have a big enough assembly table right now and am working on my uneven garage floor and driveway. I don’t want to cut anything, then i will be just chasing my tale.
I was thinking of sanding the legs just a tad….. Any advice on how to get them all perfect would be great! They are going to be sitting on a deck. They are perfectly fine now, but I want it to be perfect!
Thanks!
Brandon
5 replies so far
View Oldtool's profile
Oldtool
2596 posts in 2156 days
#1 posted 04-16-2013 01:11 PM
They are perfectly fine now, but I want it to be perfect! Which is it?, perfect or not?
1. If the legs are only 1/32” off when empty, and set without rocking when used, why worry?
2. If you do get them perfect on a flat reference like a table saw top, who’s to say the deck will be as flat?
I think you are worrying way too much about this. Go with it as it is and enjoy the build.
-- "I am a firm believer in the people. If given the truth, they can be depended upon to meet any national crisis. The point is to bring them the real facts." - Abraham Lincoln
View casual1carpenter's profile
casual1carpenter
354 posts in 2441 days
#2 posted 04-16-2013 01:14 PM
Brandon, I am a bit confused. Since you are setting your benches on a hard uneven surface the likelihood of shifting your bench with four legs all contacting a variable contour is hit and miss. Your benches could be perfect and still they would rock slightly on an uneven contour surface. With that said, I suggest you taking the benches to the deck and move them around in the general area you intend to use them, you might find them to be reasonable.
View Woodwrecker's profile
Woodwrecker
4137 posts in 3541 days
#3 posted 04-16-2013 01:24 PM
How about putting some height adjustable feet pads on the bottoms of the legs, or locate a place on the deck they sit flat.
They also may just relax with a little use this summer and put themselves into proper aluignment.
Let us know what works for you.
-- Eric, central Florida / Utor praemia operibus duris
View waho6o9's profile
waho6o9
8165 posts in 2543 days
#4 posted 04-16-2013 01:27 PM
View Kreegan's profile
Kreegan
1452 posts in 2112 days
#5 posted 04-16-2013 04:06 PM
