How best to do this?
« back to Joinery forum
Forum topic by mds2 posted 04-16-2013 01:46 AM 914 views 0 times favorited 6 replies Add to Favorites Watch
View mds2's profile
mds2
310 posts in 2119 days
04-16-2013 01:46 AM
Here is a joinery question for everyone. I need to make a tapered through mortise in a piece of 3/4 walnut. The tapered mortise is also at a skew; the tenon piece is at an angle to the walnut mortise piece. Also none of the sides of the mortise are straight, think of the cross section as a trapezoid with all sides arcing out. A puffy trapezoid.
Additional to this, the tenon is also curved. Also the face with mortise will be arched. The size of the tenon is roughly 2”x2”
I’ve thought about this a little bit for the last couple nights. Right now I’m thinking hog most of the material out with a drill and file to fit. File. Test fit. File. Test fit. File. Test fit…
117276 posts in 3752 days
#1 posted 04-16-2013 01:51 AM
Sounds interesting . I would make the tenon first and follow your plan.
View Planeman40's profile
Planeman40
1273 posts in 2936 days
#2 posted 04-16-2013 01:54 AM
When you get this done, we would ALL like to see it! Me, I think I’d nail it together. :)
Planeman
View mds2's profile
mds2
#3 posted 04-16-2013 01:55 AM
Ah yes, I should mention the the tenon is already made. Think of it as a giant fang, because that is what it looks like.
View Loren's profile
10477 posts in 3823 days
#4 posted 04-16-2013 02:13 AM
Files.
View Woodknack's profile
Woodknack
12399 posts in 2555 days
#5 posted 04-16-2013 03:30 AM
Well I was ready to say drill it out in steps with diminishing size bits then I read “curved”. I think you’ve made it too easy, it should also corkscrew <g>. Good luck and I want to see lots of pics.
View mds2's profile
mds2
#6 posted 04-17-2013 01:45 AM
Here is the second attempt. Pretty sloppy and the other side is much worse. This isnt the final shape of the maple piece but I thought I’d practice. I’ve done about all the shaping I can with that plane in the background. My spokeshave should come in the mail tomorrow and I am very excited to use it! Though I imagine I will have a lot of tearout in this maple. I ended up just chopping out a mortice and using a rasp to fit. I keep having problems in the corners where the rasp tends catch and cut too deep. I actually had a blowout on the other side of the top hence why I’m not showing it. I need to be more diligent.
There is another piece that will be above this one. It intersects the “tooth” in a similar manner, just at an upward angle. I’ve decided I’m going to bend them after I fit them. Maybe.
