Bandsaw wheel rubs on upper housing
Forum topic by ayryq posted 04-15-2013 10:04 PM 1297 views 0 times favorited 3 replies Add to Favorites Watch
View ayryq's profile
94 posts in 2127 days
04-15-2013 10:04 PM
When the blade tracking is adjusted “back” enough the top of the upper wheel rubs on the fixed sheet metal housing. If it’s just rubbing a little bit, closing the upper door fixes it (not sure why).
Has anyone run into this? Any idea how to fix?
It’s a Ridgid bandsaw.
3 replies so far
View Tedstor's profile
1643 posts in 2568 days
#1 posted 04-15-2013 10:31 PM
Has it always rubbed or is this a new issue?
Is your blade possibly a bit too long?
#2 posted 04-15-2013 10:57 PM
Always has. With thinner blades I just let them track toward the near side of the upper wheel. I was putting on a wider (1/2”) blade today and had to move the tracking back, so it started rubbing again.
It may be unrelated (old blade?) but I see a slight forward-and-backward oscillation in the blade as I turn the wheels. What jigsaw makers would call “oribital.”
Busted the blade guard/guide mount in the process, and thought while I was working on getting that fixed I’d see if anyone had any ideas about this rubbing.
View Surfside's profile
3389 posts in 2109 days
#3 posted 04-17-2013 08:34 PM
I think it is just a proper blade tracking and adjustment.
-- "someone has to be wounded for others to be saved, someone has to sacrifice for others to feel happiness, someone has to die so others could live"
