Teach me your finishing tricks: bandsaw boxes
Forum topic by Elizabeth posted 04-15-2013 08:27 PM 6561 views 1 time favorited 17 replies Add to Favorites Watch
View Elizabeth's profile
817 posts in 3077 days
04-15-2013 08:27 PM
Topic tags/keywords: question trick cedar finishing
I’m making some bandsaw boxes out of western red cedar. Obviously there’s a lot of end grain involved. I’m new to bandsaw boxes and to finishing in general. I have put on two coats of Danish oil but the end grain is still looking dry and patchy. Also, the glue lines (I used Titebond) are pretty obvious, but this seems to be a hit-or-miss problem, as some lines are okay and others are really horrible. One in particular is very obvious and diffuse and I wonder if the spindle sander rubbed bits of glue into the wood pores.
What advice would you give to reduce these problems? Should I have used a different glue? Is Danish Oil no good for this, or is it okay but I need to do many more applications? Should I sand down to a finer grit? What would you use to put a final “polish” on the box, and is whatever-it-is compatible with having Danish oil underneath?
17 replies so far
View LookingGlass's profile
77 posts in 2042 days
#1 posted 04-15-2013 08:47 PM
I too have this problem with using cedar. Perhaps we will get some pointers.
-- Take care.....Ed
View Nicky's profile
695 posts in 4026 days
#2 posted 04-15-2013 09:05 PM
The glue lines could be due to uneven surfaces. If your using a mechanical sanding method, like your spindle sander, the glue will heat and possible leech around the glue lines. I don’t think this is a glue problem. I’m just thinking out loud.
End grain will absorb a lot of finish. Hard to say how many coats, but keep applying, you’ll get to a point where it evens out. Cedar is a softwood, and I would sand up to 320 or 400. I’d use wax as the final polish (after the oil has cured). The drawback with wax is that you could not put another coat of oil, and that may be just fine for a bandsaw box.
-- Nicky
View Blackie_'s profile
4856 posts in 2446 days
#3 posted 04-15-2013 10:38 PM
interlocks fingers while bending fingers back popping knuckles getting ready to type :) Ah Elizabeth Bandsaw boxes are my specialty but only if it hadn’t been for other fellow LJ’s that got me started, I kind of just took the bull by the horns and went my own direction with it, I’ll be glad to pass down to you what was taught to me in the bandsaw box world.
Here are some items
1. Spindle Sander (a must have) 1/4” up to 2” sanding sleeves with #80 #150 and #240 grits
2. 4” to 6”Belt sander ( a must have) # 80 grit
3. a couple 4” sanding blocks one with 80 grit and the other with 150 grit
4. Sanding paper I use #80 #150 #220 or #240 either or, #400 and lastly #600 in this order.
5. For all of my finishing I use a single quick coat of tung oil then a wipe to bring out the grain then 2 to 3 coats of wipe on poly using a foam brush dipping only the corner of the brush it doesn’t take much, then after drying time I final coat of paste wax.
As for as the glue goes you have to sand it real good in order to remove the glue and upon gluing you have to be careful on the squeeze out, I try to wipe as much off as possible and sand the rest as glue will not take finish at all, it has to be completely removed.
End grain soaks up the finish so sometimes it takes a lot of applications, I think the oil fills the pours better then the wipe on poly but I normally just keep applying the poly upon dry times until it’s had enough.
Hope this helped if you have any questions please don’t hesitate to send my a PM and ask, I’ll be more then happy to help.
-- Randy - If I'm not on LJ's then I'm making Saw Dust. Please feel free to visit my store location at
View designeratheart's profile
8 posts in 1801 days
#4 posted 04-15-2013 11:55 PM
I don’t know about Elizabeth, but it sure helped me! I am not doing boxes, but I am going to be doing a whole lot of finishing and this is wonderful information to have.
Thank You!
-- Smile! It makes the day so much better!
#5 posted 04-16-2013 09:40 AM
Great info for me too. The one coat of tung followed by the wipe on poly is interesting…..I have only used one or the other alone and not together. I use the sponge corner dipped in the finish; apply; wipe with cotton cloth.
Thanks for taking the time to give the pointers. I have some boxes in work and will post how this technique worked.
-- Take care.....Ed
#6 posted 04-16-2013 10:02 AM
I’d like to add that finishing is a whole different world so many avenues to take, What I posted above is what I found to be my niche or groove and am finding it’s working great for me, Another thing about finish is what type of sheen you are looking for be it flat, satin or gloss and this topic has been brought up here on LJ’s a time or two, (is it a guy or girl thing? Which room is it going into? etc….) myself I like a gloss sheen and have never tried a satin and am myself still learning these avenues, for example a kitchen recipe box, I would think it would take on better a satin or even a flat appeal as most kitchen related items aren’t very shiny, as I’ve witnessed when doing shopping in these areas.
As for as oils go they need longer drying times as well before applying any other finishes such as poly and such.
View coachmancuso's profile
259 posts in 1865 days
#7 posted 04-16-2013 11:11 AM
I just did a red cedar band saw box. I sanded the box with 80, 120, then 220. I started the finishing with 2 heavy coats of Danish oil, let it dry for 1 week then start with wipe on poly. I will put 4 – 6 coats with sanding in between coats with 400. To end it all 1 coat of Johnsons paste wax. Hope this helps
-- Coach Mancuso
View Gene Howe's profile
Gene Howe
10258 posts in 3362 days
#8 posted 04-16-2013 01:27 PM
As to gluing: It helps to apply a very thin coat to both pieces, rubbed in with a finger and allowed to dry, before applying the final glue to seal the joint. This insures that the final glue will not soak in to the end grain and starve the joint. With the knowledge that soaking in has been eliminated, you can then afford to apply less glue and also fairly well eliminate squeeze out. If possible, you could tape both sides of the joint to catch any errant glue.
Finishing is really wood specific. Softer woods will require more applications unless you use a sealer. My favorite finish for small band saw boxes is BLO or Watco first. Flood it and let is sit for a while. Do not let it get tacky. Then wipe it off and let it completely dry. (At least 24 hrs.) Re-apply if necessary.
When you are satisfied that the wood will accept no more, apply the final finish of your choice.
With harder woods, I use a 50/50 blend of either Watco. or BLO, and Marine varnish from start to finish.
#9 posted 04-16-2013 04:01 PM
Thanks for your input – this is all really helpful and I’m glad to see others have the same questions!
Randy and Coach Mancuso, when you say “wipe on poly” do you mean polyurethane?
View bbasiaga's profile
1163 posts in 1929 days
#10 posted 04-16-2013 04:59 PM
Wipe on poly is a thinned poly urethane that you can apply with a cloth or foam brush. I just tried it after hearing about it here. I LOVE IT. It goes on very even and doesn’t run, drip or pool the way traditional poly can. Mainly because you can apply a very light coat. After 3-4 coats it still looks very natural (not ‘plasticy’), but imparts a nice amber tone to the wood.
I used the Minwax because it was available locally. You can also make your own by diluting regular poly with mineral spirits…or so I’ve been told.
#11 posted 04-16-2013 05:05 PM
OK, thanks. I picked up a small can of polyurethane after work yesterday (Walmart was my only option, so the choices were limited) but I don’t know if it’s specifically “wipe on” or not. I’ll have to check when I get home.
View wncguy's profile
369 posts in 2246 days
#12 posted 04-16-2013 05:39 PM
I have had issues getting darker color on end grain (walnut & maple boxes). I was using Watco Natural Danish oil. I asked Charles Neil for suggestions (he is VERY helpful) & he suggested first wiping the end grain with a damp cloth the immediately apply the oil. According to him it sounds nuts but helps a lot & doesn’t affect the adhesion.
He noted other options too, but this sounded really interesting. I’m going to try it on some scrap pieces this week.
-- Any man can be a father, but it takes someone special to be a Dad
#13 posted 04-16-2013 05:45 PM
“Randy and Coach Mancuso, when you say “wipe on poly” do you mean polyurethane?”
Elizabeth yes to your question to polyurethane and what Brian said, As a matter of fact I mix my on poly blend, I use a 60% poly to 40% mix of mineral spirits it’s much cheaper doing it that way. Doesn’t sound like what you bought Elizabeth is a wipe on, the “wipe on” comes in a tall thin can with a twist off top which is sold at lowes.
16273 posts in 4152 days
#14 posted 04-16-2013 05:59 PM
Elizabeth, one trick is to wipe your box down with lacquer thinner before applying any finish. Any remaining glue will show up pretty clearly, and you can address the problem before you go any further.
View Jim Finn's profile
Jim Finn
2641 posts in 2856 days
#15 posted 04-17-2013 12:02 AM
Applying lacquer thinner as Charlie suggests is what I do. Mineral spirits will also work. In places where it is very difficult to wipe up any squeeze-out of glue I use titebond hide glue instead. When finish is applied over it , it virtually disappears, unlike other glues.
