The problem: Getting a good 35mm hole from a flatted shaft bit
Forum topic by Lee Barker posted 04-15-2013 04:25 PM 1088 views 0 times favorited 5 replies Add to Favorites Watch
View Lee Barker's profile
Lee Barker
2170 posts in 2723 days
04-15-2013 04:25 PM
Since my Mepla hinge machine left I’m boring doors with my drill press. I can’t seem to get that bit shaft centered in the chuck and the result is sloppy fit.
I’d love to find a metric bushing (10mm ID) that slipped on the shaft.
Any ideas for source? Or better solution to the problem?
I did finally find a full-round 35mm bit but it was a piece of junk. I’d like to stay with the quality bit I have.
Kindly,
5 replies so far
View Terry Ferguson's profile
Terry Ferguson
203 posts in 2539 days
#1 posted 04-15-2013 04:39 PM
McMaster-Carr
drill bushing #8486A49
10mm ID, 15mm OD, 20mm length
-- Terry Ferguson, Bend Oregon
View RogerInColorado's profile
RogerInColorado
321 posts in 1827 days
#2 posted 04-16-2013 05:19 AM
I have used a 35 mm bit but I am actually happier with a 1 3/8 inch forstner bit from Porter-Cable. It has a 1/2 inch shank with three flats. It’s a tiny bit smaller than a 35 mm (0.00295 smaller), but the fit for the hinge is a really good press fit, no slop. May be worth a try.
View vipond33's profile
vipond33
1405 posts in 2370 days
#3 posted 04-16-2013 05:32 AM
You need a split in the bushing to pull up tight. I use a 10mm router bit sleeve by Makita for those odd times. Works great if you align it properly.
gene
-- gene@toronto.ontario.canada : dovetail free since '53, critiques always welcome.
Lee Barker
#4 posted 04-16-2013 03:02 PM
Gene uttered the key word: Makita. I recalled I had a couple bushings that came with my old Makita D-Handle routers. They’re made to bush a 3/8 router bit shaft up to 1/2. The shaft measured 9.9mm, .389. .014 difference. Aha!
I tapered the end of the bit shaft so the bushing would start. Used my Record woodworking vise as a press.
I gave it a test drill and voila! vipond! Nice fit with the hinge. I’m glad I save stuff.
(And speaking of hinges, I’m using the self closer hinges from Grass on this linen cabinet. Pretty sweet.)
Thanks for all the input.
Kindly,
Lee Barker
#5 posted 04-16-2013 03:36 PM
Here’s another solution:
Kindly,
