drill press crank extension
Forum topic by yofranzy posted 04-15-2013 08:06 AM 5681 views 0 times favorited 5 replies Add to Favorites Watch
View yofranzy's profile
yofranzy
1 post in 1835 days
04-15-2013 08:06 AM
Topic tags/keywords: jig resource
I’m new to this site and I’ve noticed several posts regarding drill press enhancements. I just acquired a Delta 11-990 that was in terrible shape. The crank handle was broken off and now that I’ve replaced it I’d like to extend it. The spindle that it attaches to is 1/2”. What are the various options for attaching the extension rod to the spindle? Any suggestions would be much appreciated.
Jim
5 replies so far
View macatlin1's profile
macatlin1
78 posts in 2910 days
#1 posted 04-15-2013 10:21 AM
I purchased a drill press table from Harbor Freight for my HF drillpress and when I installed it I found that it interfered with the table crank. I took off the crank and found a socket (11mm I think) that fit the shaft . I bought a new socket and drilled and tapped for a setscrew. The table now fits against the column. To operate I just use a ratchet to raise and lower the table.
View jimmyb's profile
jimmyb
185 posts in 1859 days
#2 posted 04-15-2013 12:08 PM
LOL, did the same thing with my HF drill press.
-- Jim, Tinley Park, IL http://jbuda.net
View JoeinGa's profile
JoeinGa
7735 posts in 1974 days
#3 posted 04-15-2013 12:35 PM
If you want to EXTEND the handle, perhaps you could make an extension from 1/2” pipe? You might need to drill some holes for a bolt or pin
Should be fairly easy to do
View Lee Barker's profile
Lee Barker
2170 posts in 2817 days
#4 posted 04-15-2013 03:57 PM
This is the coolest DP trick I’ve ever learned. Thank you! I had extended the handle of my crank but that was not efficient. The ratchet handle is brilliant.
A 14mm socket is just right on my old Rexon (Taiwan) machine. I know a junk store where I can find a quality single socket and I think I’ll just epoxy a cheap ratchet handle to it.
Before the sun sets in the west I’ll have this done!
Thank you macatlin and jimmyb!
Kindly,
Lee Barker
#5 posted 04-15-2013 09:25 PM
I failed to take any before pictures. Trust me, it was a knuckle buster. Here’s the result of today’s gold ingot from LumberJocks:
I got the ratchet handle and the socket for two bucks. The rest was a little labor on my part and great thinking on yours.
Thanks again guys. Excuse me now while I go drill some holes in various sizes of stuff.
Kindly,
