first try at box joints
« back to Joinery forum
Forum topic by jeffswildwood posted 04-15-2013 12:48 AM 854 views 0 times favorited 2 replies Add to Favorites Watch
View jeffswildwood's profile
jeffswildwood
3055 posts in 1946 days
04-15-2013 12:48 AM
Hello all, just wanted to let you all know I made my first attempt at box joints today. OMG practice very much needed. Pins were narrow and slots were wide. Not even a straight cut! It did fit nicely at the very end though. I give myself a D- on this but I know I can only get better from this point. Couldn’t get worse. The only reason I didn’t make it an E is I did use hand tools. No power tools at all, box saw and coping saw. Like I said back to basics for me. I’m going to school on this and will keep you posted til I finally post a project with box joints correct. Thanks for listening.
-- We all make mistakes, the trick is to fix it in a way that says "I meant to do that".
2 replies so far
View Dallas's profile
Dallas
3599 posts in 2456 days
#1 posted 04-15-2013 01:39 AM
Good Luck, box joints, especially by hand do present a bit of a learning curve.
It might help if you can get a small mortising chisel to clean the sides and ends.
View luv2learn's profile
luv2learn
2755 posts in 2272 days
#2 posted 04-15-2013 02:59 PM
Give yourself some time and be patient. Nothing that is worthwhile is easily learned.
-- Lee - Northern idaho~"If the women don't find you handsome, at least they ought to find you handy"~ Red Green
