Steel City Granite TS with Incra LS32-TS
Forum topic by marty341 posted 04-14-2013 08:05 AM 1228 views 0 times favorited 4 replies Add to Favorites Watch
View marty341's profile
marty341
2 posts in 2087 days
04-14-2013 08:05 AM
Topic tags/keywords: tablesaw fence steel city incra granite ls32-ts 35926
Does anyone have any experience with adding an Incra LS32-TS table saw fence system to a Steel City 10 inch TS with a granite top, e.g. a 35926? I am seriously considering the Steel City 35926 and would very much like to add the Incra fence. I am concerned about any compromises in accuracy, stability, and repeatability that I may have to make. Any advice and shared experience will be greatly appreciated. Thanks,
Marty
-- Marty, Indialantic, Fl.
View IrreverentJack's profile
IrreverentJack
727 posts in 3043 days
#1 posted 04-14-2013 04:31 PM
Marty, I have a LS32 and I’ve been interested in granite topped saws, more so after looking at the manual. The LS32 mounts easily to most saws. The only question I had is whether the stock rails(front and back) are necessary to provide strength to the table and extensions. I didn’t know about the robust castings on the top of the cabinet used to mount the granite and tie it together. IMO mounting the LS32 fence directly to the granite would probably be fine but if I were you I’d call Incra and ask them. Steel City might help you too. If you have to incorporate the stock rail(angle iron) into the installation it still wouldn’t be difficult. Compromises in accuracy, stability, and repeatability aren’t an issue with Incra. -Jack
View Charlie's profile
Charlie
1100 posts in 2486 days
#2 posted 04-14-2013 04:39 PM
I have a 35990 granite top. The wings don’t need the fence rails for stability or strength. If the 35926 uses 4 bolts into each wing as my 35990 does, then the fence rails aren’t needed for support/strength.
As long as the supplied brackets with the LS32 will give you the correct HEIGHT, I think you’ll be fine.
View ScrubPlane's profile
ScrubPlane
190 posts in 2396 days
#3 posted 04-14-2013 04:45 PM
While I cannot add any comments with respects to the Steel City saw I can share that I have Incra products for my router table, router jig, drill press, as well as several additional ‘home designed’ jigs and fixtures assembled from various Incra components.
I can tell you unequivocably that if done correctly and with patience, you’ll find the Incra after market add-ons are ‘generally’ superior to OEM.
Take your time and good luck…John
View WoodJitsu's profile
WoodJitsu
49 posts in 2993 days
#4 posted 04-15-2013 07:59 AM
I have the Ridgid granite saw and it’s made by steel city (or the same Chinese factory pumps them out anyway). I put the Incra fence on it so I have some experience. First, the fence mounts and works fine on the granite top, so no worries there. Overall, the system is a great idea and the adjustments are precise and save you time… But, the TS fence system has some flaws that eventually led me to sell it. It requires a lot of space on the right hand side of the saw for the aluminum arm to move freely. Also, the fence is locked down with a little turn knob. This is an inferior method compared the standard lever/cam lock. I also found that the fence had a hard time remaining square. Just too many places of adjustment and movement. And reading the measurement is a pain because it’s way off to the right. I always found myself hunched over to the side making readings and adjustments. Setting up the saw for the router table was never fun because you had to slide everything over and calibrate, etc. I’m theory, the system is brilliant. In practice, it’s ok. You’d be better off getting a Biesemeyer.
-- Family, Friends, Jiu Jitsu, Woodworking. Order varies daily!
