curly maple
Forum topic by bryanstryin posted 04-14-2013 08:04 AM 1191 views 0 times favorited 13 replies Add to Favorites Watch
View bryanstryin's profile
bryanstryin
6 posts in 1833 days
04-14-2013 08:04 AM
Topic tags/keywords: wood maple curly maple tear out planner jointer finishing
Hello, my name is Bryan . I wanted to no what can I do about tear out on this curly maple . If I run on the jointer, or run it through the planner I get TEAR out. any tips. I thank you for any help. And one other thing can you sand the tiger strips out .that may sound funny but if you don’t no. I see others work, with figured maple and its so great. I would love to get mine to look that way , with out all the tear outs. thanks again.
13 replies so far
View nwbusa's profile
nwbusa
1021 posts in 2249 days
#1 posted 04-14-2013 08:52 AM
If your tools don’t have a helical (spiral) cutter head then tear out can be a problem. Very light passes might help somewhat, otherwise you’re in for a lot of sanding. I’ve also had some success using a high angle blade in my hand planes. Good luck.
-- John, BC, Canada
View Monte Pittman's profile
Monte Pittman
28900 posts in 2301 days
#2 posted 04-14-2013 08:54 AM
Either the wood is too green or the blades are dull would be my guess.
Welcome to LumberJocks
-- Mother Nature created it, I just assemble it.
View Marcus's profile
Marcus
1163 posts in 1982 days
#3 posted 04-14-2013 10:03 AM
I suppose its just the equivalent of fancy sanding, but on my curly maple, I find that hand planes are the only way to get a nice smooth finish with no tearout.
View sprucegum's profile
sprucegum
324 posts in 1960 days
#4 posted 04-14-2013 10:31 AM
I sometimes give the wood a rubdown with wood glue a day or two before planing thinning the glue a little hekps ( most of the popular ones are water base so you can use water for thinner). Working the glue into the cracks and pours then letting it cure well seems to help bond the fibers.This treatment is only good for one or two lite passes then you need to retreat it or go to sandpaper. The glue can also be problem if you plan to use stain on your project. Sometimes reversing the direction you are feeding the wood from helps, sharp blades and lite passes are a must.
-- A tube of calk and a gallon of paint will make a carpenter what he ain't
Marcus
#5 posted 04-14-2013 10:35 AM
Do you have any issues w/ finishing after coating a piece in glue?
Marcus
#6 posted 04-14-2013 11:18 AM
No tearout, but a bit of a sore shoulder…
sprucegum
#7 posted 04-14-2013 11:49 AM
As I said in my post the glue can be a problem if you plan to use stain. Glue left in the cracks and pours will act as a sealer. If the project is well sanded after it is planed a natural finish is not a problem. I wish my beat up old joints would allow me to use more hand tools without pain, I have 3 sharp hand planes in the shop and several others kicking around that are not so sharp, I rarely use them.
bryanstryin
#8 posted 04-14-2013 02:01 PM
thanks so much to all of you for your help. Great tips. going to give them a try
View Robert Tutsky's profile
Robert Tutsky
58 posts in 2013 days
#9 posted 04-14-2013 03:04 PM
Bryan, I have had some luck by wetting the surface of the wood with water. It will help soften the wood fibers a bit before sending it through the planer or jointer. Very light passes helps also.
-- http://www.benchtopwoodworkingtools.com
View darthford's profile
darthford
567 posts in 1887 days
#10 posted 04-14-2013 04:47 PM
Byrd Shelix cutter head tear out gone!
117060 posts in 3540 days
#11 posted 04-14-2013 04:52 PM
I agree with using a spiral head planner and or dampening the wood before planing.
Marcus
#12 posted 04-14-2013 06:24 PM
Never tried dampening the wood, I’ll have to give that a shot. Great tip.
View richardwootton's profile
richardwootton
1699 posts in 1918 days
#13 posted 04-14-2013 06:45 PM
I second, or third, wetting the surface and light passes. Sharp blades are also key.
-- Richard, Hot Springs, Ar -- Galoot In Training
