Question On Link Belts
Forum topic by ChuckV posted 04-14-2013 01:16 AM 1359 views 0 times favorited 3 replies Add to Favorites Watch
View ChuckV's profile
ChuckV
3119 posts in 3526 days
04-14-2013 01:16 AM
About six years ago, I replaced the 1/2” V belt on my jointer with a link belt. I bought a 1/2” link belt, but found that there was not enough clearance around the upper pulley. I used that belt on my drill press instead and bought a 3/8” link belt for the jointer. It has been working great ever since.
Today I picked up an older lathe. I plan to replace the 1/2” V-belt with a link belt here too. I tested with a piece of 1/2” link belt and again there is not enough clearance between the upper pulley and the guard. The link belt does not sit as deep in the pulley as the original belt.
Maybe I just ran into two cases where the pulley geometry does not match that of the link belt. The jointer is a Delta from 1999 and the lathe is a Rockwell from 1974.
Has anyone else noticed this?
-- “Big man, pig man, ha ha, charade you are.” ― R. Waters
3 replies so far
View punk's profile
punk
181 posts in 2415 days
#1 posted 04-14-2013 12:14 PM
im restoreing adelta lathe from the 40’s belt sits high but works great
-- Punk in PA
View PurpLev's profile
PurpLev
8535 posts in 3647 days
#2 posted 04-15-2013 01:01 AM
the link belts are flat belts and not v-belts, hence they do not fit “into” the pulleys as the original belts. just the nature of the beast. as long as there is enough tension on there it should work just fine though. you can always get ‘gates’ brand belt which is a v-belt and is a high quality belt (and does not develop memory bumps) for a 1/3 of the cost of a link-belt
ChuckV
#3 posted 04-15-2013 01:12 AM
Sharon,
The ones that I got from Fenner are V-belts. They do have a V profile, but it seems that the angle is different, which causes the difference in where they ride on the pulley.
