Even bigger triangle - Copy and Past
Forum topic by niki posted 06-02-2007 05:35 PM 1486 views 1 time favorited 5 replies Add to Favorites Watch
View niki's profile
niki
426 posts in 4107 days
06-02-2007 05:35 PM
Good day
If you remember the post “Triangle Copy and Past”
http://lumberjocks.com/topics/249
and “Triangle after copy and past”
http://lumberjocks.com/topics/252
I made bigger 45° triangle 20-11/16” x 20-11/16” x 29-1/8”
I used an Aluminum straight edge after checking with caliper that it has consistent width.
You can use even a plywood strip but it must be consistent in width all along.
You can stick the straight edge with Carpet tape (if it’s Aluminum like mine) or screw it (if its wooden or ply).
You can use any width of straight edge, depends by how much you want to “enlarge” the triangle (I used 3¼” wide).
The rest is very simple, you just chuck a bearing guided straight bit and “Copy” side after side.
Finished all 3 sides
Checking for 90° on a straight edge
This is my TS
Back to the router table with ¼” straight bit
I had enough plywood to make 2 of them
The strip for the base was also made very consistent in width , then, I made a groove for the triangle and glue it with CA (super glue).
Thank you
niki
5 replies so far
View mot's profile
mot
4911 posts in 4064 days
#1 posted 06-02-2007 07:01 PM
Thanks for the detail! Excellent work and equally excellent idea!
View WayneC's profile
WayneC
13754 posts in 4125 days
#2 posted 06-02-2007 07:47 PM
Great as always sir. Keep up the great posts.
35125 posts in 4428 days
#3 posted 01-16-2008 02:02 AM
Niki Looks like all of the pictures are gone. Do you still have them available, somewhere?
View niki's profile
niki
#4 posted 01-16-2008 09:23 AM
Thank you Karson
When I lost my Photobucket account, some posts pictures also disappeared but, as I promised, I will re-load any post pics that will be requested.
Regards
niki
View rikkor's profile
rikkor
11295 posts in 3902 days
#5 posted 01-16-2008 11:40 AM
Very nice “how-to.”
