Tape on luon
« back to Coffee Lounge forum
Forum topic by Jim Earl posted 04-13-2013 05:44 PM 1037 views 0 times favorited 5 replies Add to Favorites Watch
View Jim Earl's profile
Jim Earl
451 posts in 4214 days
04-13-2013 05:44 PM
Topic tags/keywords: humor resource tip question
I have a peice of luon that has had a piece of tape on it and after removing the tape it seems that the glue stayed on the wood, Does anyone have a cure or remody on hoe to remove the glue withour hurting the wood. can you help. Jim Earl
-- Jim Earl http://www.myspace.com/earle5
5 replies so far
View BoxBuilder's profile
BoxBuilder
129 posts in 3128 days
#1 posted 04-13-2013 05:47 PM
Don’t know if this will work for you but anytime I have to remove sticky residue I use WD-40 and then a good scrubbing with rough cloth. Good luck.
-- Richard, Pennsylvania
View Radu's profile
Radu
330 posts in 3041 days
#2 posted 04-13-2013 06:09 PM
You can try to warm it up with a hair drier and use a scraper to take it off. I would not use WD40, but mineral spirit or acetone should work.
View stefang's profile
stefang
15881 posts in 3332 days
#3 posted 04-13-2013 07:06 PM
Maybe mineral spirits or Ethanol (denatured spirits) if the mineral spirits doesn’t work.
Jim Earl
#4 posted 04-13-2013 07:14 PM
I want to thank you all for your help. I used mineral spirits and it took all of gummy off. left a stain but I can cover that up, again thank you all. Jim Earl
View SnowyRiver's profile
SnowyRiver
51457 posts in 3478 days
#5 posted 04-13-2013 08:24 PM
Another product for your memory bank is called Goo Gone. You can purchase it at most grocery and hardware stores. It removes the tape residue on just about anything quickly. I use it a lot on my truck when changing window stickers out…LOL…or if you buy something that has a sticker on it and you cant get it off. Its non toxic and can even be used on clothes.
-- Wayne - Plymouth MN
