poser:
Take the fence off the bandsaw table and set it aside. Then, take the board, as described above, and set it flat on the table and carefully, by hand, saw down the line until you are about 1/2 way down the board. Due to the blade’s unique “leade”, you will probably notice that the board is situated at somewhat of an angle on the table. Thus you have defined the leade for that particular blade.
Without disturbing the board, and the angle to which it is laying, carefully clamp it in place. Then, get the fence, loosen it’s adjustment screws, and place it against the clamped board and tighten the screws. Now you have a fence that is perfectly adjusted to compensate for the leade of the blade. Note: If you change blades, you will have to go through this procedure all over again.
If your bandsaw table can accomodate a feather board, you can adjust it so that it presses the stock that you are resawing against the fence. Position the feather board just before the blade so as not to “squeeze” the wood against the blade.
I hope this helps.
