Question for the hand saw users out there .....
« back to Hand Tools forum
Forum topic by Oldtool posted 04-12-2013 02:31 PM 1007 views 0 times favorited 4 replies Add to Favorites Watch
View Oldtool's profile
Oldtool
2732 posts in 2368 days
04-12-2013 02:31 PM
Topic tags/keywords: question saw filing sharpening
To the hand saw users out in there Lumberjocks land, I have a question regarding my intended sharpening of three hand saws I own:
In total, I have 6 hand saws, two of which are 26” panel saws & one a relatively new PAX Dovetail saw – Rip Cut, none of which are under consideration here in this survey / question. What I am about to sharpen soon, now that I received my Lie Nielsen package of saw files, are the following three saws:
16” blade length (handle dimension not included) Disston back saw, currently filed 12 PPI Cross cut, 3 3/4” cut depth
14” blade length Disston back saw, currently filed Rip Cut with 13 PPI, 3 1/2” cut depth
12” blade length Jackson back saw, currently filed Rip Cut and 13 PPI 2 5/8” depth of cut.
My question is:
What method of filing (Crosss cut versus Rip) would you find most useful if you were to apply it to these three saws, assuming the intent is to use them as much as possible for furniture work; tenon, dovetail, and other hand saw use? I don’t plan to change the PPI, because I’ve found these do a better and faster job than the 22 PPI PAX, even in their current state of dullness.
Thanks in advance for the advice, I’m looking to make any changes to these saws once – for all future use.
Oldtool
-- "I am a firm believer in the people. If given the truth, they can be depended upon to meet any national crisis. The point is to bring them the real facts." - Abraham Lincoln
View RGtools's profile
RGtools
3372 posts in 2832 days
#1 posted 04-12-2013 02:43 PM
I would file the 16” as rip, file the 14 as x-cut, and leave everything else as is.
16 tenon
14 carcass
12 DT
Adjust things after you Have worked with them a bit. Slow adjustments tend to work out better over the long haul.
-- Make furniture that lasts as long as the tree - Ryan
View Tim's profile
Tim
3812 posts in 2139 days
#2 posted 04-12-2013 03:26 PM
It would be helpful to know the depth of the blades on the three saws. The 16” probably is pretty deep so Ryan has it. But sometimes they’re odd. Also some people recommend a crosscut dovetail saw for some uses and since you have the other Pax, that might not be a bad way to go for you. A 22 ppi saw is for pretty fine work so if you’re not using it for that it’s going to cut slower than you’d hope. So having a lower ppi rip filed dovetail might suit you better than having it crosscut. It’s up to you in the end.
Oldtool
#3 posted 04-12-2013 06:33 PM
Tim,
I included the depth of cut above, 3 3/4”, 3 1/2” & 2 5/8” depths respectively.
If this changes anything, please let me know,
Thanks
Oldtool
View Kreegan's profile
Kreegan
1452 posts in 2324 days
#4 posted 04-12-2013 06:58 PM
I would agree with Ryan. If you’re feeling adventurous, you might try a hybrid approach on the 14”.
