Thoughts on my pallet glueup method
« back to Joinery forum
Forum topic by savan posted 04-12-2013 02:15 PM 1289 views 0 times favorited 1 reply Add to Favorites Watch
View savan's profile
savan
97 posts in 2535 days
04-12-2013 02:15 PM
I’m planning on trying a new to me method of joining pallet slats into boards up to 24×48.
How well do you think this will work, any improvement suggestions?
1. Acquire a stack of pallet slats
2. Using a router and a straight edge straighten one edge
3. At the table saw rip slats into 3” or 4” boards
4. Edge glue slats using biscuits
Note that I don’t have a planer and not in a position to get one right now. I’m using TBII and the biscuits are purely for leveling of one face of the pallets.
The problem is that the boards vary widely in thickness from 1/2” to 3/4”. My hope was that by using the same biscuit joiner settings on all boards that I’d end up with one close to flat side that I would then use as the exterior surface of whatever I’m making.
I don’t want to plane the boards anyway so I can keep the aged look of the pallets.
Any thoughts on how well this will work? Any suggestions for getting as close to flat/even on one side as possible?
Thanks!
1 reply so far
View Sandblastguy's profile
Sandblastguy
42 posts in 2255 days
#1 posted 04-12-2013 02:26 PM
There is no reason why it won’t work. Take your time and put a biscuit about every 12”. Don’t put so much glue on that a lot squeezes out that has to be removed. Try to reverse the grain on each board to control warping. Good luck
-- Sandblastguy Orangeville On. Creating Art From Nature
