Air filtration
Forum topic by shelly_b posted 04-11-2013 07:36 PM 2257 views 0 times favorited 37 replies Add to Favorites Watch
View shelly_b's profile
shelly_b
850 posts in 2118 days
04-11-2013 07:36 PM
I was thinking about getting an air filtration unit for my shop, but wanted to know if they make a big difference and are really worth it. It is impossible for me to keep my shop clean right now. I would have to dust like twice a day. It’s not only from my woodworking dust, we live on a gravel road so I get that dust too. So, for those of you that have one, did it really cut down on the dust in your shop?
37 replies so far
View Dallas's profile
Dallas
3599 posts in 2487 days
#1 posted 04-11-2013 07:47 PM
Does it do any good?
I’d have to say it made a world of difference.
I built my own with a high volume squirrel cage out of a squirrel cage from a roof top RV air conditioner. I built a box around it and use 2 20X25 MERV 13 filters on the intake ends. The exit is out the top.
I have it on a pedestal by the wall about 8’ from my work table and using the belt sander without a vacuum collection the system collects about 90% of the dust. Very little dust is left on the table and none anywhere else in the shop.
I’ve been changing the filters about once a month when I use the shop 3-6 hours a day.
View Elizabeth's profile
Elizabeth
817 posts in 3144 days
#2 posted 04-11-2013 07:52 PM
I can always tell, on walking into my shop, whether or not I remembered to turn on the air filter before leaving the last time. If you’ve got the space and have the need, get one.
And I need to start changing my filters more often, too…
shelly_b
#3 posted 04-11-2013 07:54 PM
Thanks guys. I’d like to build my own…but if I come across a good used one I may grab it. The dust is driving me crazy!!
Elizabeth
#4 posted 04-11-2013 07:59 PM
I think this is the newer version of the one I have:
http://jdstools.com/air-tech-hp-air-cleaner.aspx
What I like best about it is the remote with the ability to set low-med-high speeds and have a shutoff delay of 1 to 4 hours. You can also do this with buttons on the unit itself, which is useful because my remote batteries died surprisingly fast.
View nwbusa's profile
nwbusa
1021 posts in 2286 days
#5 posted 04-11-2013 08:01 PM
It’s made a huge difference in my shop. I get much less of the fine dust on my machines when I use it at the end of the day. Periodically, I blow out my shop with the shop vac blower, and when I’m done I just set the air filtration unit to run for a few hours. Well worth it in my opinion.
-- John, BC, Canada
View Mainiac Matt 's profile
Mainiac Matt
8047 posts in 2329 days
#6 posted 04-11-2013 08:08 PM
I have the Jet AFS-1000 and like it a lot…
imo you need the thick fabric sock type filter to get the fine stuff….
the hot air furnace type pre-filters won’t cut it by themselves…. even if stacked several deep.
I turn mine on pretty much every time I run a power tool and for sure, every time I run my DC.
My shop is 23’x21’ and the filter turns over the entire air volume of the shop very quickly…..
Just the other day I was hand routing and couldn’t really catch the dust at all….. So I ran the filter on high and the shop air was cleaned up in no time.
Grizzly makes a knock off of the Jet for quite a bit less money.
-- It’s the knowledge in your head, skill in your hands and motivation to create in you heart that makes you a woodworker. - Mainiac Matt
View b2rtch's profile
b2rtch
4861 posts in 3048 days
#7 posted 04-11-2013 08:13 PM
Make your own.
I made mine, it makes a huge difference.
It is easy and relatively inexpensive to build.
-- Bert
View whitebeast88's profile
whitebeast88
4128 posts in 2190 days
#8 posted 04-11-2013 08:32 PM
i have a jet afs-1000 also and love it.i hung it over my workbench and it cuts down on alot of dust.you can tell it cuts the dust fog out of the air real quick(sometimes i forget to turn it on).
another thing to help cut down on dust is a down draft sanding table/box make a huge differance also.
-- Marty.Athens,AL
View SteveKnnn's profile
SteveKnnn
66 posts in 1888 days
#9 posted 04-11-2013 08:35 PM
Every dust collection/capture/filtration tool is worth it. Breathing is too important.
Now to remember to turn them on, change filters etc.
-- Steve in Richmond, VA
View Glen's profile
Glen
9 posts in 3064 days
#10 posted 04-11-2013 08:48 PM
I use 2 (doubled up) 20×20 filters on my home made unit – a furnace fan inside of a box that I built. I find that if I cover the outside filter with bounty paper towels the paper towels pick up the finest dust. When they start to discolor, its time for new towels on the filter. When the outside filter will start to discolor I will put the new filter on the inside of the stack and use the old inside filter on the outside – the paper towel side. I’ve been using the original filters for over 2 years. I was thinking about putting a timer on the unit but find that if I turn it on when I first start working there is little or no dust in the air by the time I finish cleaning up what I was doing.
Dallas
#11 posted 04-11-2013 09:12 PM
Glen That’s a cool idea using the paper towels. I might give that a try.
shelly_b
#12 posted 04-11-2013 09:43 PM
Thanks guys. I’m convinced…I def. need one now! I’ll keep an eye on craigs list and look at designs to make my own in the mean time…
shelly_b
#13 posted 04-11-2013 09:43 PM
If I end up with 2 thats better anyways right:)
b2rtch
#14 posted 04-11-2013 10:03 PM
Shelly, this is how I made mine:
http://lumberjocks.com/topics/45679
If you need help PM me
-- Bert
View toolie's profile
toolie
2123 posts in 2629 days
#15 posted 04-11-2013 10:17 PM
while you’re waiting, if you can source a 20” box fan cheaply enough, you can do this as a semi permenant or temporary solution:
i got luckily fell into some 1” drywall jchannel . vinyl siding j channel will work equally well. cheap, fast and easy.
i used the 1 hr timer as i had it lying around. this would be a better option, adn i’ll change at some point:
http://www.homedepot.com/p/t/202788262?catalogId=10053&langId=-1&keyword=timers&storeId=10051&N=5yc1v&R=202788262#.UWc19KJgSSo
showing 1 through 15 of 37 replies
