Saw Blades?
Forum topic by dbissot posted 57 days ago 142 views 0 times favorited 7 replies Add to Favorites
View dbissot's profile
dbissot
7 posts in 65 days
57 days ago
Topic tags/keywords: blade saw dado
Any recommendations on the type of saw blade to purchase for hardwoods? How many teeth, brand, etc?
Also, what type/brand of Dado blade would you recommend? Thanks for your ideas!
View jim1953's profile
jim1953
171 posts in 378 days
57 days ago
I use freud Industrial blades 24t I use it all the time my dado blade is makita 6in.
-- Jim, Kentucky
9873 posts in 358 days
57 days ago
I use Forrest blades in all of my saws. I generally use the Woodworker II 40 tooth blade for ripping and crosscutting. For dadoes I use the Forrest dado set. For melamine and plywoods I use the Duraline 80 tooth blade. These blades are pricey but with my Craftsman saw I need all the help I can get to make good cuts. These blades have gotten top reviews in several woodworking magazines.
View juniorjock's profile
juniorjock
358 posts in 302 days
57 days ago
Can’t beat the Woodworker blades. Good stuff.
-JJ
-- Make things with wood.
View Gofor's profile
Gofor
73 posts in 324 days
57 days ago
I have had good luck with Freud. 50t combination for most work. Full kerf industrial one if your saw will handle it. (LU84R011). After that, a good 24t rip blade for thick boards, and a 60t or 80t for fine cutting edges. I also have the Freud SD208 dado set and am happy with it. Upgraded from a Vermont American 6” that did okay but did not give me flat bottoms in the dadoes. I would advise against any of the wobble type adjustable dado sets. The will give a round bottom and are not worth the price. I have a 6” Craftsman that I will not give away because I would not do that disservice to a fellow woodworker!. For comparison to your saw, I am using a Ridgid TS3650 13 amp (110v) contractor saw (belt drive). I prefer the full kerf blades as they warp less when resawing thick wood. I have found a quality full kerf blade will cut as well as a cheap thin kerf, can be resharpened, and is more stable.
Go
-- Go http://ncwoodworker.net/pp/showgallery.php?cat=500&ppuser=730
View ChuckV's profile
ChuckV
21 posts in 64 days
57 days ago
I agree that the Forrest blades are great. I use the Workworker II full kerf with 40 teeth. I also have the Freud D1080X 80 tooth, which is a very good crosscut blade. My dado set is the Forrest Dado King 8”.
-- Chuck - Wood Chiseler's Rule #1: Mom was right - "Don't pick at it!"
View Chris 's profile
Chris
1259 posts in 528 days
57 days ago
While I own the Forrest Woodworker II; any of the major brands will give you very good performance as long as your saw is aligned properly. I have the Forrest for the cross & rip cuts and a CMT dado set.
I would say that be it CMT, Freud or Forrest it’s hard to go wrong….
-- Chris
View Bob Chapman's profile
Bob Chapman
6 posts in 60 days
56 days ago
I use Forrest blades in all my saws – I have always been very happy with their performance. They are not cheap but you generally get what you pay for.
Bookmark And Share This Page
