Stuck Trunnion
Forum topic by Flyfisher posted 04-11-2013 06:15 AM 1114 views 0 times favorited 10 replies Add to Favorites Watch
View Flyfisher's profile
Flyfisher
2 posts in 2679 days
04-11-2013 06:15 AM
I have just acquired a mid seventies Sears table saw. In overall good shape, but the trunnion is not working properly.
The angle adjustment is incredibly stiff. It will not move beyond one or two degrees from vertical.
Any suggestions on where to start looking will be appreciated.
Thanks!
G
10 replies so far
View JawShoeAh's profile
JawShoeAh
28 posts in 1869 days
#1 posted 04-11-2013 10:46 AM
I just got done taking apart a similar saw. The trunions hold the whole saw in place with a friction fit. It just rides metal on metal. I would suggest cleaning it out and lubing it. I think people like to use that dry silicone lubricant so dust won’t stick to it like regular grease would.
-- .·..-._.·¨ ¤ Joshua
View GrandpaLen's profile
GrandpaLen
1650 posts in 2267 days
#2 posted 04-11-2013 11:56 AM
+1 for Joshua’s suggestion.
You could also use the new product from WD-40, spray White Lithium Grease, available at Lowe’s Home Depot and most large Hardware stores.
Best Regards. – Grandpa Len
Work Safely and have Fun.
-- Mother Nature should be proud of what you've done with her tree. - Len ...just north of a stone's throw from the oHIo, river that is, in So. Indiana.
View GT350's profile
GT350
368 posts in 1976 days
#3 posted 04-11-2013 12:42 PM
Just to make sure, did you loosen the lock handle on the front of the saw?
Mike
View SamuraiSaw's profile
SamuraiSaw
515 posts in 1959 days
#4 posted 04-11-2013 12:50 PM
+1 on Mike’s suggestion. On the front of the saw above the height adjustment is a locking knob. That’s for the bevel adjustment. Make sure it is loosened.
-- Artisan Woodworks of Texas.... www.awwtx.com
View IrreverentJack's profile
IrreverentJack
727 posts in 2838 days
#5 posted 04-11-2013 03:34 PM
I would avoid using silicone. I’ve seen a few finishing nightmares that were presumably caused by tiny amounts of stray silicone. I have had good luck with paraffin or candle wax. I rub or melt it onto the threads, teeth and trunnions and it lasts a good while. -Jack
JawShoeAh
#6 posted 04-11-2013 05:00 PM
Jack, that’s really interesting. How often do you re apply?
View Craftsman70's profile
Craftsman70
244 posts in 2120 days
#7 posted 04-11-2013 05:11 PM
I just went through this. Don’t try turning it to hard or the whole top base may bend. Take it apart and clean it and remove all traces of grease. I then coated everything with Johnson’s wax and then applied Dupont Multi-use lubricant to trunnions and gears. That stuff is like a wax with Teflon in it.
View dschlic1's profile
dschlic1
427 posts in 1964 days
#8 posted 04-11-2013 05:26 PM
On my Craftsman saw there is also a spring loaded screw in the rear trunnions. This might also be set to tight. In any case a complete disassembly is not out of order on a new purchase.
Flyfisher
#9 posted 04-11-2013 05:33 PM
Thanks for all the help. Cleaned strange looking crud and sawdust of screw, lubed, and now works like a charm. Good suggestions about the front lock and rear screw, both were ok.
IrreverentJack
#10 posted 04-11-2013 06:50 PM
Joshua, I haven’t yet. It’s been over 3 years – still operates smoothly. There is sawdust is built up inside but not sticking to the teeth. On another saw I mixed paraffin with mineral spirits over hot water and brushed it on. That was a PITA so I “borrowed” some candles on my newer saw and dripped it on. I had the saws apart/upside down when I did it. If I had better dust collection and maybe compressed air to clean it out more often I would probably use white lithium grease. -Jack
