Restoring surface on old Craftsman Series 100 Tablesaw
Forum topic by jordanp posted 04-10-2013 04:02 PM 9413 views 0 times favorited 9 replies Add to Favorites Watch
View jordanp's profile
jordanp
1086 posts in 2175 days
04-10-2013 04:02 PM
Topic tags/keywords: table saw ts tools reconditioning restoring craftsman series 100
Hey guys,
Craftsman Series 100 TS
Just wanted to get some of your thoughts on restoring/cleaning this old table saw surface.
I was told not to use wire brushes or sanding because it create shallow dips in the surface and it would not be dead flat any more.
the top is smooth it is just very discolored due to age.
I will try and post some pics tonight.
thanks in advance..
-- J. Palmer Woodworks - Rockwall TX -I woke up this morning thinking “man, I really hope someone posted some soul scarring sh*t on LJs today.” -- - Billy
9 replies so far
View Davynurse's profile
Davynurse
53 posts in 2156 days
#1 posted 04-10-2013 04:17 PM
I just resurfaced my “New to me” Delta contractors saw last week, I bought some rust remover from the big box store applied it like the instructions said and it was a disaster. Now keep in mind I only had light surface rust but this stuff totally discolored the table top and I freaked so I broke out the ROS and 220 paper and some WD-40 and went to work, finished up with a light sanding at 400 then cleaned it with alcohol and coated it in paste wax and it looks brand new and still dead flat!, there are a lot of good products on the market to help but just be careful if you try a cleaning solution.
-- Arguments with furniture are rarely productive. (Kehlog Albran)
View bondogaposis's profile
bondogaposis
5148 posts in 2585 days
#2 posted 04-10-2013 04:49 PM
Evapo-Rust works well.
-- Bondo Gaposis
View Mainiac Matt 's profile
Mainiac Matt
8609 posts in 2563 days
#3 posted 04-10-2013 04:51 PM
check out my TS re-hab blog you can see how I did it…
cast iron is not that hard….
hand sanding with a block seems to be an accepted technique… but be careful about using power tools
-- I yam what I yam and that's all what I yam
jordanp
#4 posted 04-10-2013 05:11 PM
Thanks guys for all tips, I’m going to post some pictures tonight and work on it this weekend, I will follow up with some before, during and after pictures of the restoration.
View toolie's profile
toolie
2148 posts in 2863 days
#5 posted 04-10-2013 08:57 PM
i found this segment of a unisaw restoration series by FWW magazine to be very informative:
http://www.youtube.com/watch?v=MSJjN8jvdp4&feature=relmfu
i followed the videos instructions duiring a unisaw refurb and here’s the before and after:
before:
and here’s the after:
cheap, easy and effective. no evaporust or naval jelly.
View oldretiredjim's profile
oldretiredjim
206 posts in 2620 days
#6 posted 04-10-2013 09:09 PM
I used Liquid Wrench and 220 grit wet sand paper. Spray, drink a beer, hand sand. Repeat. Use mineral spirits at the end of each day. Took me 3 days at 2 hours a day. I am very happy with mine and wrote up the process in a blog. i have a lot of bees wax and I use that on the surface periodically. It isn’t that hard to do and if it is just surface rust the chemicals pull it out of the pores in the cast iron without hurting the surface.
jordanp
#7 posted 04-11-2013 04:44 AM
Really nice resto there toolie. The extentions on my ts should be fun because they are not solid top so there are gaps kinda looks like a torsion box grid
jordanp
#8 posted 04-11-2013 04:52 AM
Here is the ts in its current state..
Im going to look at those guides and see what i can do
toolie
#9 posted 04-11-2013 12:51 PM
i have webbed CI wings on one of my TSs. i addressed those with a wire wheel. fast, easy and a bit messy (i.e., rust dust shot all about)
