Delta Bench top Jointer, Need Review
Forum topic by USCJeff posted 548 days ago 1519 views 0 times favorited 15 replies Add to Favorites
View USCJeff's profile
USCJeff
815 posts in 605 days
548 days ago
Topic tags/keywords: jointer
I need a review on the Delta JT160 6’’ Variable Speed Bench Jointer. There are some online reviews, but I had more specific questions. The consensus from what I gathered is that the fence needs a lot of tuning to get to 90deg. The fence is aluminum which is a negative. However, I was thinking of attaching UHMW auxiliary fence to it anyhow. I won’t use the jointer at any angle but 90. I joint 45 a different way. Long story short, if I add the aux fence and fine tune it to 90, will it stay at 90 for the most part? All jointers need the occasional realignment, but should stay there for a while. My philosophy is to buy the best so that I make only one purchase with no regrets, but a floor model will take up very much needed space. I can spend more and get a floor model, but space is more of an issue at this point. A lot of my tools roll under benchtops, but I’m about at capacity. It would require removing base cabinets to create new space. I wouldn’t buy an 8” jointer since my miter saw has a 6” reach.
Delta Benchtop
-- Jeff, South Carolina
View WayneC's profile
WayneC
5684 posts in 634 days
548 days ago
I have a 6” Jointer on rollers and wish I had saved a little more an gotten an 8”. Perhaps you could put a floor model on rollers and move it out of the way when working.
I would think hard on a bench top model if your doing any kind of larger work. What kind of projects are you planning?
Also, I see quite a few benchtop jointers on craigslist. Perhaps you could find an inexpensive used one there to use and determine if a benchtop jointer meets your needs.
View Bill's profile
Bill
2524 posts in 698 days
548 days ago
I have a Ridgid 6” jointer that I bought last year at Home Depot. It has served me well so far, and is good for what I need. I would like a larger jointer, but they are much more expensive as well as take up more space. The 6” has been a good compromise for me.
I would say get the free standing jointer instead of the benchtop. The larger table would work much better, unless you are only jointing smaller items. I believe the free standing jointer will also be more powerful too. I would say the Ridgid would probably fit under your workbench, as it is not too tall. If not, maybe you make a case to fit over it, and have additional storage there.
Wayne has a good point about trying out the benchtop before you buy one (if possible). I think you will find a larger model would work better, even if it does take up some floor space.
WayneC
548 days ago
Oh and $5 says you will outgrow the mitersaw in the next few years. I had a smaller one and it frustrated me to no end to be 1/2” or 1” short on cut capacity. Although hand saws work well in that situation.
USCJeff
548 days ago
I do wish my miter saw was a 12” and not a 10”. My Dad has the 12” version of my Dewalt and I have used it a few times. The extra inch or so makes a difference. Like Wayne said, I am often an inch or so short of the board width. I can flip it over, or go the handsaw route.
Craigslist in my area has not caught on as much as other places I’ve seen. There are a decent number of listings, but no where near what a couple of other large cities nearby have. I’ve found a few good sources for reclaimed lumber from demolisions there.
View mot's profile
mot
4859 posts in 573 days
548 days ago
I bought the same Ridgid as Bill, about three years ago. It’s too small. I would expect that you would do better to find some space and get a free standing one. I have found that, especially face jointing, a heavy sturdy tool is really an asset. I’ve looked at those little jointers before I had one and they seem awfully Mickey Mouse. No offence to anyone that has one.
USCJeff
548 days ago
Yeah, you all are probably right. I think I’ll table the idea and rethink my shop’s layout to accomodate a sturdier unit. My brother in law bought an 8” Shop Fox jointer last month. It’s HUGE, but it’s awfully pretty! It weighs a ton. His shop is in an attic that covers the whole house. The only entry is from an exterior staircase. I’ve helped him carry the jointer, table saw, bandsaw, and 1000BF of red oak up there. Makes me appreciate my ground level shop.
View mot's profile
mot
548 days ago
I don’t know if you’ve seen my shop layout, Jeff, but I raised my tablesaw so my jointer can tuck under the left wing. It sticks out about 10” past the wing and doesn’t take up much more space than my TS. Carrying the tables to a 8” jointer up a stairwell would be a real nutbuster! No wonder you want that little dude.
View surplusdealdude's profile
surplusdealdude
42 posts in 547 days
547 days ago
I’ve worked a lot with UHMW (see my profile for why). One thing to keep in mind is that you should run the UHMW through a surface planer before screwing it to your fence. UHMW can vary in thickness as much as 7% of the width and still be considered to be not defective. I’ve seen UHMW with hollows and crowns before its planed that would certainly throw your jointing off.
Another option is to use a plastic called Delrin (generic name acetal, pronounced ah-see-tal). This is a much more rigid plastic than UHMW and a lot more slippery. It’s also more expensive, but I sell offcuts of it at my ebay store for reasonable prices, if you’re interested.
-- surplusdealdude
surplusdealdude
547 days ago
Sorry, forgot to mention that I have set up a UHMW help center in Google groups. I have put all of the little ins and outs of working with UHMW that I’ve picked up in about 10 years of working with the stuff in there. URL for it is;
http://groups.google.com/group/uhmwtips/browse_thread/thread/d8feeae7a6d07e05
-- surplusdealdude
USCJeff
547 days ago
UPDATE: I took Mot’s advice and started looking for more space in my shop. I don’t want to store it under a counter as it is a very wide machine. I would have to remove at least two of my base cabinets. My planer and a trash can are already under the spot where I embedded my miter saw. Something had to go or be drastically altered. It pained me to do it, but I dismantled my traditional workbench that I made when I first got started. I planed the top about an inch and attached a sheet of MDF via pocket screws to it. I bordered it with maple for a nice contrasting look. I attached this top to a 2X4 fixed the wall via lag bolts. I installed some heavy duty hinges so that the top can drop flush to the wall when not needed. I hinged the legs to fold in wards into the bottom of the table. I had to hollow out a portion of the table bottom to allow the legs to completely fold. In the end, I will have 10’-12’ more square feet in floor space.
View Jim's profile
Jim
40 posts in 535 days
535 days ago
I was in the same boat as you with limited space. I found an older mode(1989?)l that was never used with the base kit on CL for $75.00 and the guy also had a 2 gal compressor that was older but like new in the box for $50 so I bought them both. It works great for what i need if and when I get my big shop I will upgrade all my tools as needed.
-- Jim in Cushing Oklahoma
View Dollarbill's profile
Dollarbill
91 posts in 674 days
534 days ago
I have a Delta 4” benchtop and it is pure junk. Aluminum is a poor choice for a table top of any kind.
I now have a Grizzly 6” and love it.
Bill
-- Make Dust
USCJeff
534 days ago
I decided to pass on getting a jointer for now. I’ve got a pretty good setup for jointing on my tablesaw or router table for many applications. It’ll get me by for the time being. I’ve been putting off getting a dust collector for a while as its a very boring purchase. I’m in a 10X20 shop so the air gets pretty bad very quick. I have access to an 8” Shopfox jointer at my brother-in-law’s shop for major milling.
WayneC
534 days ago
LOL. We will see how long this decision lasts. : ^ )
Dust collection is always a good investment.
View mot's profile
mot
534 days ago
I think and re-think until I decide to think some more. The birth of my shop was a painful process like a new bride, a big living room, a bunch of new furniture and a husband with a sore back. I look forward to the outcome here too!
Bookmark And Share This Page
