Where on the arc of Stanley chisels does this one live?
« back to Hand Tools forum
Forum topic by Lee Barker posted 04-09-2013 04:25 PM 998 views 0 times favorited 6 replies Add to Favorites Watch
View Lee Barker's profile
Lee Barker
2170 posts in 3090 days
04-09-2013 04:25 PM
Topic tags/keywords: chisel
Thrift store find. $.75. How did I do? No markings except Stanley molded into the handle. Rough machining on the blade.
Kindly,
View longgone's profile
longgone
5688 posts in 3548 days
#1 posted 04-09-2013 04:48 PM
Looks like one of those Stanley chisels that are sold at Wally Mart for $10 a set of four.
View Loren's profile
10477 posts in 3888 days
#2 posted 04-09-2013 04:49 PM
I have seen those before. I figured they are a standard carpenter
chisel from the 60s and 70s.
They could be new like Greg says.
View dahenley's profile
dahenley
136 posts in 2333 days
#3 posted 04-09-2013 04:54 PM
they are a new style….
im a broke college student and its what i purchased first and still have. you can sharpen them with stones and they work ok. ( have never compared them… )
i will say that the backs are usually not flat… .and take a little to get sharp, but they have worked for me on my first few projects.
i think i got mine from Lowes or HD
and yes, they come in a set of 4
-- David Henley
View ratchet's profile
ratchet
1391 posts in 4027 days
#4 posted 04-09-2013 05:00 PM
The difference between your chisel and a fine chisel is less than you think. Flatten the back and grind till the nicks are gone then get it sharp (method of your choice) till it easily shaves the hair off your arm. You can then do some serious work with it. Caution: do not grind it till it gets blue or worse red hot. Keep quenching it in water to keep the blade cool. You do not want to remove the temper from the steel.
View bondogaposis's profile
bondogaposis
5153 posts in 2591 days
#5 posted 04-09-2013 09:04 PM
Did you buy a chisel or a saw? Nice nicks, it look it has been used for everything except a chisel. I think the steel in those is pretty good.
-- Bondo Gaposis
View vernacular's profile
vernacular
13 posts in 3076 days
#6 posted 04-09-2013 09:24 PM
must be for chiseling IN woodgrain patterns. Yup, a faux grain chisel. I think you got a steal.
-- Plant as many trees as you can
