Table top options for barn wood
Forum topic by AnthonyC posted 04-09-2013 02:19 AM 3582 views 0 times favorited 10 replies Add to Favorites Watch
View AnthonyC's profile
AnthonyC
50 posts in 3053 days
04-09-2013 02:19 AM
Topic tags/keywords: barnwood table reclaimed
Hi all,
I have a beautiful pile of reclaimed barn wood from my in-laws. Some boards are in great shape, some not so much. A good gray patina, worm holes, and original saw mill marks.
Haven’t counted the board feet yet, but I think I have enough 5/4 to make a 4×6 kitchen table top (probably trestle, but not sure yet). Some 8/4, probably enough for a base, and one beam (16/4), but it has enough checking I’m considering not using it.
Anyway, the planning problem now is the milling and finish: keep the saw marks and patina (and have limited joinery options, a non-perfectly flat table top) or mill it like regular boards down to 1”, lose the patina and saw marks (still plenty of worm holes, dings and such), but have a more usable top.
Just asking for advice, experience, or examples. Unlike my other projects, I only get one shot to get this one right :)
Thanks in advance,
Anthony
-- Amateur woodworker, professional mess-maker.
10 replies so far
View kdc68's profile
kdc68
2689 posts in 2424 days
#1 posted 04-09-2013 02:40 AM
AnthonyC...Well I’d keep as much of the patina and all the character as possible. It would make a great trestle table top. I’d plane one face (the face you don’t want to be the “money” side) of each board of the top to a uniform thickness and joint the edges . Plan ahead so that you joint only the edges for gluing up edge to edge…keep one edge of the two outside boards as is. Glue the boards together with the” money” faces up and the surfaced faces down (underside of the table top) and two unjointed edges to the outside. That way you would have all the character that you want and the top would be a consistent thickness. Breadboard the ends
-- Measure "at least" twice and cut once
View Lee Barker's profile
Lee Barker
2170 posts in 2997 days
#2 posted 04-09-2013 02:51 AM
I think it’s a two sided coin. I like kdc’s approach, but I also like old boards that have been planed down and have nail holes with black areas around them. It is possible to build a table with an impermeable top (filling those nail holes with black epoxy) and still get the “I’m made of repurposed stuff” message loud and clear.
If you wish to keep the gray, experiment with using the ol’ steel wool and vinegar on a cut edge. My experience has been that you can’t tell the old edge from the cut edge. A wire wheel in a drill and you’ve got it.
Here’s a blog Google suggested when I searched “steel wool and vinegar.”
Kindly,
View Don Broussard's profile
Don Broussard
3665 posts in 2398 days
#3 posted 04-09-2013 02:59 AM
I made this bench out of old cypress barn wood. I hand planed the exposed edges, retaining any nail holes, but I left the hidden faces with their history intact. You can have it both ways.
I like kdc’s suggestion as well. I didn’t have the issue with edge glue-ups, since the barn boards were wide enough to make the five-board bench without having to do a glue-up.
-- People say I hammer like lightning. It's not that I'm fast -- it's that I never hit the same place twice!
kdc68
#4 posted 04-09-2013 03:03 AM
Lee…the blog was a dead end for me when I opened it
Don…that’s a handsome bench…nicely done !
AnthonyC
#5 posted 04-09-2013 01:54 PM
I’ve got enough scrap that I think I can do a test board—sand, plane, leave it alone, oil /poly, etc. To see what we like and what we don’t.
And great idea on just planing one side. I hadn’t thought of that. Of course, the boards are very close to the same thickness now, but at least the bottom would be ruler flat to the trestle.
Might do the testing this weekend. I’ll post some pics if it’s successful.
thanks for the ideas,
Anthony
Lee Barker
#6 posted 04-09-2013 06:39 PM
The link didn’t work for me either.
Let’s try this:
http://peachstreet.blogspot.com/2011/07/vinegar-steel-wool-wood-stain.html
Kindly,
View sixstring's profile
sixstring
296 posts in 2390 days
#7 posted 04-09-2013 06:45 PM
got any pics of the wood? if you kept the patina and original surface mostly untouched, how would it be finished to have a useful and non-splintering top? the perfectionist in me wants to mill it down to have all 4 surfaces square, but using the reclaimed wood is always nicer when it retains it’s charachter. have fun with this project!
-- JC Garcia, Concord, CA : "It's easier to ask forgiveness than permission..."
View bandit571's profile
bandit571
21298 posts in 2830 days
#8 posted 04-09-2013 07:12 PM
I think I might have a project or two out of Barn wood. maybe a box?
There are a few others, as well.
View JayT's profile
JayT
5879 posts in 2358 days
#9 posted 04-09-2013 08:11 PM
I made a desk with barnwood for the top. In order have a flat surface, while preserving character, it has an epoxy finish. I was planning a similar dining table. You can still see the color and saw marks through the finish and if the boards didn’t match up exactly on thickness, it wasn’t an issue.
View JoeinGa's profile
JoeinGa
7739 posts in 2154 days
#10 posted 04-09-2013 10:58 PM
Here’s what I built from some 100-year-old barn wood that was given to me. The wife and I are pretty pleased with the finished product
http://lumberjocks.com/projects/77110
