Curved crown moulding
Forum topic by rrdesigns posted 04-09-2013 01:24 AM 2181 views 0 times favorited 6 replies Add to Favorites Watch
View rrdesigns's profile
rrdesigns
531 posts in 3183 days
04-09-2013 01:24 AM
I am seeking help in how to create curved crown moulding for the top of an armoire. Any ideas? I want to recreate this piece.
-- Beth, Oklahoma, Rambling Road Designs
View REO's profile
REO
928 posts in 2071 days
#1 posted 04-09-2013 01:30 AM
we used to use a hussy planer with ground blades for odd mouldings like this. your best bet is most likely a router and several passes of diferent profiles and a pattern to follow. the router wll have to be guided at two points unless you can swing a router bit wide enough to cut in one pass.
View Nicky's profile
Nicky
695 posts in 4089 days
#2 posted 04-09-2013 01:39 AM
1+ on what REO said.
I just saw this on a New Yankee Workshop episode. This is a two part build, and I believe Norm shows the router setup in the second episode. May be worth a look for an idea on setup.
Part 1 https://www.youtube.com/watch?v=usB02xeqwlU
Part 2 https://www.youtube.com/watch?v=Cz6dqO7iUO8
-- Nicky
rrdesigns
#3 posted 04-09-2013 05:11 AM
The links above won’t play. Message says they are private. Any other suggestions on how to find them?
View shipwright's profile
shipwright
7980 posts in 2795 days
#4 posted 04-09-2013 05:29 AM
Hi Beth, I made rounded crowns on my kitchen cabinets at home a few years ago. I used a trick I saw in some magazine FWW I think.
1) Make your straight molding and cut a 1/8” section slice off one end.
2) Cut a block 2x the depth (front to back) of the molding and a couple of inches longer than the molding is high.
3) Make a 1/8” kerf 1/2 way through the block, top to bottom and push the cut off slice(midway along the kerf) in until it bottoms.
4) Chuck the block in a lathe and turn until you just reach the imbedded slice.
5) You can now divide the turning into 4 round corners exactly like the straight molding.
They’re actually a little short of 90 degrees because of saw kerfs but it’s easy to hide. It’s a good idea to mark the molded edge of the slice with a black marker to make it easier to see when turning. I don’t have any construction photos but here’s a finished one.
shipwright
#5 posted 04-09-2013 05:30 AM
Oops! Sorry I should have read more closely. .... :-(
Nicky
#6 posted 04-09-2013 05:53 AM
I have a sign in for youtube.
I subscribed to a publisher called digitalPimple who had a lot of New Yankee videos. I watched a few, and the one that I thought could help you with an idea was called “How to build a Queen-Ann highboy.” Norm demonstrated the method that REO mentioned. Norm used multiple router bits to create the profile in a curved molding, similar to your piece.
I just opened another window and I get the same as you. I watched these this past Saturday (really).
-- Nicky
