Dust Collection Hose Question
Forum topic by luvmyfingers10 posted 04-08-2013 06:10 AM 1395 views 0 times favorited 17 replies Add to Favorites Watch
View luvmyfingers10's profile
luvmyfingers10
5 posts in 1692 days
04-08-2013 06:10 AM
I recently bought a 3 hp (240 V) dust collection system from Grizzly and also bought 20 feet of heavy duty clear wire reinforced hose. Upon receipt, I noted that the hose really wants to retract so I stretched for several days as I put copper braided wire inside to dissipate static electricity. When I turn on the dust collector, the hose still wants to retract and I am concerned about the braided wire getting ingested by the collector. Any ideas?
17 replies so far
View doyoulikegumwood's profile
doyoulikegumwood
384 posts in 3809 days
#1 posted 04-08-2013 06:28 AM
you will get lots of differing answers to this one I happen to believe running a ground wire inside your collection pipe is allot of whoey. and my guess would be it will eventually end up sucked in to your blower.
-- I buy tools so i can make more money,so ican buy more tools so I can work more, to make more money, so I can buy more tool, so I can work more
View pmayer's profile
pmayer
982 posts in 2882 days
#2 posted 04-08-2013 07:24 AM
Why won’t the wire that is built into the hose serve as a ground?
View ellen35's profile
ellen35
2732 posts in 3249 days
#3 posted 04-08-2013 10:46 AM
I threw mine away and bought a more “friendly” hose. That stuff is impossible!
4719 posts in 2310 days
#4 posted 04-08-2013 11:24 AM
Yep, toss the wire….it’s unneeded.
Shawn Masterson
1322 posts in 1765 days
#5 posted 04-08-2013 12:24 PM
Return what you bought and get the strech hose from rockler. I got one and love it. As for the ground it’s unnessary but if you want use the wire in the hose A lose wire is a catch hazard and disaster if the impeller got ahold of it.
View Picklehead's profile
Picklehead
1040 posts in 1746 days
#6 posted 04-08-2013 01:26 PM
It sounds like you might not be getting enough air FLOW through the hose if it’s trying to retract. Don’t confuse that with not enough suction, as that 3 hp obviously has more than enough. If the hose isn’t connected to a machine, does it try to retract? If you plug the end of the hose while it’s running, it will retract due to the high vacuum pressure and no airflow. My guess is that if you are able to get more air flow through the machine it’s connected to, it might reduce the retraction issue (and also improve dust collection). Someone will be along shortly, no doubt, and either explain this better or point out where I’m mistaken.
That said, all of the above info also sounds spot on!
-- You've got to be smarter than the tree.
View TheDane's profile
TheDane
5312 posts in 3479 days
#7 posted 04-08-2013 02:03 PM
I wouldn’t suggest putting the ground wire inside the hose … chips & dust could accumulate between the wire and the hose.
The hose’s wire reinforcement can function as a ground, but only if the bare wire is attached to something that is attached to ground. The plastic in the hose is an insulator, and floating grounds don’t do any good.
View gtbuzz's profile
gtbuzz
427 posts in 2258 days
#8 posted 04-08-2013 02:49 PM
Gonna agree with Picklehead. Really sounds like the “problem” is too much suction causing the hose to try to compress. On that note though, I wouldn’t go with the Rockler flex hose to help alleviate that problem. I’ve got both the 4” and 2.5” varieties, and I love using them to clean up around the shop, but because their natural state is in a compressed form, it’s only going to make this problem worse.
luvmyfingers10
#9 posted 04-08-2013 04:02 PM
Thanks to all for your input. The wire reinforcement is imbedded into the hose so I cannot see how this can act as a ground as it is insulated from and not exposed to the dust particles traveling through the hose. The literature I have read on this indicates that there is an explosion hazard if there is no mechanism to discharge static electricity which can build inside the hose as the dust travels through. At the same time, I certainly don’t want to suck the braided wire into the collector and damage or destroy it. I am wondering if the length of the hose (I would think greater chance as length gets longer – mine is 20 feet) has much to do with it and if anyone out there has used flex hose of similar lengths for years without going kaboom? I’m not worried about getting killed by an explosion, just what my wife would do to me if I wasn’t mercifully killed by it?
luvmyfingers10
#10 posted 04-08-2013 04:05 PM
Also, does anyone know a vendor from whom I can purchase the non expanding/contracting dust collection hose with 4 inch diameter?
View ChuckC's profile
ChuckC
824 posts in 2751 days
#11 posted 04-08-2013 04:30 PM
I was getting really bad shocks from my DC hose, all the time. I opened up the hose on the end to expose the wire that runs through it and grounded it to the DC motor. I haven’t got shocked since. I’m using the Dust Right hose from Rockler.
TheDane
#12 posted 04-08-2013 04:34 PM
I wouldn’t worry about explosion or fire … this has been beat around a lot on these forums and to the best of my knowledge, there has never been documented case of an explosion or fire caused by static in a small shop dust collection system.
The reason you ground the system is to bleed off ESD (electrostatic discharge). That keeps you from getting zapped by a spark, but more importantly provides some protection for solid-state electronics (e.g. computers, remote controllers, electronic variable speed tools, etc.) that are becoming more commonplace in shops.
To use the wire in the hose, just skin off about an inch of plastic on each end and bend the wire into a loop with a pair of needle-nose pliers. You can then connect the wire to a ground lug, strap, etc.
luvmyfingers10
#13 posted 04-08-2013 04:45 PM
Many thanks to “theDane”. I will give that a try and forward your suggestion to my wife so she can contact you and give thanks if I go kaboom :)
View OnlyJustME's profile
OnlyJustME
1562 posts in 2193 days
#14 posted 04-08-2013 04:59 PM
I believe the Myth Busters had an episode dealing with this issue using pvc pipe for dust collecting. I don’t think they were able to create the scenario that a static shock would make any type of explosion or flash point. Might want to google that in case i’m wrong.
-- In the end, when your life flashes before your eyes, will you like what you see?
#15 posted 04-08-2013 05:15 PM
It’s one of those urban myths that won’t die. I do agree that if you are having personla discomfort from static shock it may help with that…..but fire/explosion: bah, humbug.
