Pipe Clamp Glue Ups
Forum topic by MrHart posted 04-08-2013 02:09 AM 2403 views 1 time favorited 19 replies Add to Favorites Watch
View MrHart's profile
MrHart
46 posts in 2246 days
04-08-2013 02:09 AM
Hi all,
I’m trying to find the secret to keeping your work flat while using pipe clamps for glue ups. Things always want to bow up or twist or get all kitty-wampus.
I am a sponge, you all are the liquid. I need to absorb some technique.
-- MrHart
19 replies so far
View Kaleb the Swede's profile
Kaleb the Swede
1821 posts in 1932 days
#1 posted 04-08-2013 02:11 AM
I’ve found using a dowel on either side works. It seems to equalize the clamping pressure. Sounds strange but it works
-- Just trying to build something beautiful
View Grandpa's profile
Grandpa
3259 posts in 2638 days
#2 posted 04-08-2013 02:18 AM
The cheaper clamp head don’t have a very tight tolerance. The hole for the pipe is too large on some and it allows the heads to tip back and start this action. A caul will help but you have to be careful to keep it from adhering to the boards you are glueing up. Try using 2 clamps on the end. Switch sides and put a couple on the other side. Snug these up slowly keeping everything straight as you go. Half the clamps on each side of your glue up.
View kdc68's profile
kdc68
2649 posts in 2239 days
#3 posted 04-08-2013 02:26 AM
Alternate your clamps back and forth from underneath to on top.
-- Measure "at least" twice and cut once
View RogerInColorado's profile
RogerInColorado
321 posts in 1917 days
#4 posted 04-08-2013 03:32 AM
Kaleb’s suggestion about the dowels is good. Put the dowels in the CENTER of the edges of the outer boards. The idea is to “equalize” or balance the pressure of the clamps so that the pressure is neither on the top edge or the bottom edge.
Another challenge is for the joined edges, if they aren’t dead perpendicular to the faces, to at least complement each other so they don’t bow as part of the natural order of things. If you’ve seen videos or reverences to planning boards two at a time to offset any bevel, this is the reason for doing that. (If you haven’t, don’t over analyze this comment).
View RussellAP's profile
RussellAP
3103 posts in 2249 days
#5 posted 04-08-2013 03:54 AM
When I do large glue ups I clamp them flat first then clamp them together. A couple or three good 8/4 planed walnut does the trick with a good hold down clamp at either end top and bottom. After you clamp the boards together then tighten the clamps holding the work flat. Use film wrap to keep the glue from sticking to the hold flat boards.
View pintodeluxe's profile
pintodeluxe
5618 posts in 2776 days
#6 posted 04-08-2013 05:39 AM
I have a system that will give you dead flat panels without much effort.
1. Joint the edges with the “I” and “O” method. http://lumberjocks.com/pintodeluxe/blog/33797
2. Use clamps top and bottom.
3. Wide panels are glued up in phases. For instance when gluing up a 20” panel from 1×6 stock, glue up two pairs of planks first. Run those planks through the planer, and then do the final panel glueup.
4. Clamp a caul across the panel to keep it flat.
10244 posts in 3610 days
#7 posted 04-08-2013 10:53 AM
Pipe clamp saddles help keep the heads accurately aligned. You
still have to alternate the sides.
If your clamps need to bow to close your joints, your joints
aren’t accurate enough.
View bluekingfisher's profile
bluekingfisher
1250 posts in 2942 days
#8 posted 04-08-2013 12:01 PM
All of the above is usefull information, only if your jointed edges are true and square of course, any deviation from square will start the boards in your panel racking.
Don’t overlook the obvious, get yourself a good engineers square and use it to make sure the boards edge (both edges of every board) is square to its face. The basis of all good construction work is to ensure square and level, without these basic principles you will always end up with warped panels.
Good luck
-- No one plans to fail, they just, just fail to plan
View camps764's profile
camps764
867 posts in 2322 days
#9 posted 04-08-2013 12:20 PM
all of the above are great suggestions.
I would echo BlueKingFisher as well – because I’ve been there as well.
Always thought I needed a new clamping technique – better cauls, better clamps, alternate clamping direction, etc.
All of the above are very important…but the biggest helper of all was learning to joint the edges so that they are truly square.
If you don’t have a jointer in your shop and don’t have the funds for one – get your hands on a good jointer plane or rig up a jig for your table saw/router table for edge jointing. A 90 degree face will solve most of the problem.
-- Steve
Gerald Thompson
914 posts in 2197 days
#10 posted 04-08-2013 01:16 PM
I made these clamping cauls and they have been a God send.
http://www.wkfinetools.com/contrib/hendersonM/makingCauls/makingCauls-1.asp
-- Jerry
View gfadvm's profile
gfadvm
14940 posts in 2653 days
#11 posted 04-09-2013 01:51 AM
Thanks Jerry- great technique on that link
RussellAP
#12 posted 04-09-2013 02:45 AM
I think the jointer idea pays off the best. The clamp issue of having 30-50$ clamps is just ridiculous for most of us who have 70+ clamps. I make the F style HF clamps work for me and supplement with some pipe clamps. I still say that holding the boards flat with a couple 8/4 film wrapped boards is the best way to insure a flat glue up. I wish I had a machine press for it. But hey, there is nothing quite as -fun- as doing glue-ups is there? You can practice herding cats till you’re good at that, then clamping seems like a breeze.
#13 posted 04-09-2013 02:47 AM
In woodworking, preparation is everything.
Figuratively true of course, not literally.
View Lee Barker's profile
Lee Barker
2170 posts in 2813 days
#14 posted 04-09-2013 03:00 AM
I do a fair amount of glueups and I just don’t have a problem with bowing. I do not use cauls, dowels, or alternated clamps.
1. My jointer is dead accurate. I don’t need to alternate cuts. I joint by grain direction only.
2. I have Jorgensen clamps.
3. I center the work on the clamp feet (both ends). The work does not touch the pipes.
4. (And this has not yet been mentioned here) I don’t overtighten my clamps.
I feel as if this sounds arrogant, but I don’t mean it to. I want to make the point that it is possible to do it successfully without a lot of peripheral equipment.
Kindly,
View Dallas's profile
Dallas
3599 posts in 2450 days
#15 posted 04-09-2013 03:01 AM
