sharpening chisels
« back to Hand Tools forum
Forum topic by mariva57 posted 04-07-2013 03:12 PM 1915 views 0 times favorited 11 replies Add to Favorites Watch
View mariva57's profile
mariva57
666 posts in 2030 days
04-07-2013 03:12 PM
Topic tags/keywords: sharpening
I bought the Sharp 3000. I would like to sharpen this set of
chisels short of the Crown, which have a width respectively of 6-12-19-25 mm.
I tried to measure the angle of cut with the digital goniometer, and I found that from 6 to 12mm measured at an angle of 31.2 ° while the 19-25mm and measured 28.5 °.
I would like to know from you what angle I have to set.
-- The common man thinks. The wise man is silent. The stupid man discusses.
11 replies so far
View ShaneA's profile
ShaneA
6956 posts in 2624 days
#1 posted 04-07-2013 03:41 PM
The WS should have pre set angle stops at 25° and 30°. You could split the difference in the current bevel and sharpen on the 30° setting.
View shampeon's profile
shampeon
1775 posts in 2209 days
#2 posted 04-07-2013 04:51 PM
With the WorkSharp, you’re going to have to choose one of the preset angles and regrind the bevel. Fortunately, you only do this once. I bought an extra glass wheel to mount 80 and 100 grit paper for regrinding. Then I have a 200/400 wheel, and a 600/1000 wheel, with a leather hone wheel with green compound to do final polishing.
I have a set of Crown paring chisels I bought a few years ago. They’re good steel and pretty, but the factory grind wasn’t square, and the backs not particularly flat. The point is, regrinding the bevel is probably a good idea anyway. Be careful when you’re flattening the backs—always put it on the spinning disc from back to front to avoid touching the cutting edge.
View sikrap's profile
sikrap
1121 posts in 3385 days
#3 posted 04-07-2013 05:47 PM
My suggestion would be to regrind them at 25 degrees on the worksharp up to 1000 grit until you get a complete bevel and then do a secondary bevel of 30 degrees with the higher grits. You’ll find that the secondary bevel of 30 degrees helps maintain a sharp edge longer.
-- Dave, Colonie, NY
View JUC's profile
JUC
116 posts in 1916 days
#4 posted 04-07-2013 06:07 PM
I do not think that those digital bevel boxes are all that accurate. If you measure the same angel 3 times you will get 3 different answers. I agree with sikrap 25° then a secondary bevel of 30°. I think you will be happy with that.
Good Luck,
Jeffrey
-- If no one will ever see it, all the more reason to make it right
mariva57
#5 posted 04-14-2013 08:34 PM
These days I made some tests with sharpening chisels
little value and the result was good, I also made ​​the discs mdf to to paste the abrasive paper (glue spry
removable) it worked but when replacing
the abrasive paper disk has arisen this problem. (see photo)
Where did I go wrong?
shampeon
#6 posted 04-14-2013 09:37 PM
Yeah, you can’t use paper with the MDF discs, I don’t think, because you’ll ruin the disc when you pull it off, as you found out.
What you want is powdered grit and polishing compound applied to the surface. See Stumpy’s article on his WorkSharp 3000 stand for details.
View chrisstef's profile
chrisstef
17426 posts in 3032 days
#7 posted 04-14-2013 10:04 PM
Try a little heat to get the paper off. A heat gun or hair dryer has helped me.
View paratrooper34's profile
paratrooper34
915 posts in 2978 days
#8 posted 04-14-2013 10:11 PM
Mariva, the adhesive discs are better suited for the glass plates. The MDF ones use polishing compound as Shampeon pointed out.
You will find lots of useful information on this site, by a member of LJs.
http://www.stumpynubs.com/worksharp-3000.html
-- Mike
shampeon
#9 posted 04-15-2013 12:09 AM
Thanks, Mike. I was too lazy to look up the actual URL.
If you really want to use paper with your MDF discs, I suppose you could laminate some melamine to the top and bottom. But the polishing compound is easier, and possibly cheaper anyway.
mariva57
#10 posted 04-15-2013 04:19 AM
Thank you all for the help.
View Ross's profile
Ross
142 posts in 1998 days
#11 posted 04-15-2013 10:52 AM
Remember to flatten the backs of the chisels before honing the edges. It is a very time consuming task that only needs to be done once. With the exception of my mortise chisels all of my chisels are sharpened at 30 degrees with no micro-bevel. My mortise chisel bevels vary depending on the width of the chisel anywhere from 24 degrees to 32 degrees also with no micro-bevel.
-- "Man Plans and God Laughs"
