13" Ridgid Planer sniping problem
Forum topic by Tooch posted 04-07-2013 10:14 AM 4942 views 1 time favorited 14 replies Add to Favorites Watch
View Tooch's profile
Tooch
1698 posts in 1780 days
04-07-2013 10:14 AM
Topic tags/keywords: question planer
I have a 13” Ridgid Planer, and consistently find snipes at the end (last 3 inches or so) of my boards. I have been living with—this like a golfer adapting to his slice—by trying to plane entire 8’-10’ boards first before rough cutting them down to a more workable length.
Does anyone have any advice on how to fix the actual problem?
-- "Well, the world needs ditch-diggers too..." - Judge Smails
14 replies so far
View NiteWalker's profile
NiteWalker
2736 posts in 2480 days
#1 posted 04-07-2013 01:04 PM
Raise the ends of the infeed and outfeed tables.
View TheDane's profile
TheDane
5365 posts in 3567 days
#2 posted 04-07-2013 01:08 PM
+1 on NiteWalker’s advice.
Also helps if you support the ends of longer boards … especially on the outfeed side. I use roller stands on both sides if the board is over 4’ or so in length.
View Sandra's profile
Sandra
7185 posts in 1979 days
#3 posted 04-07-2013 01:36 PM
I have the Ridgid 13” planer. If the infeed or outfeed tables are off the slightest, you’ll get sniping.
I made a shop cart with adjustable outfeed arms that works great. If I get any snipe, I just readjust the level and snipe is gonzo! The cart is in my projects if you’re interested in my solution.
-- No, I don't want to buy the pink hammer.
View Charlie's profile
Charlie
1100 posts in 2190 days
#4 posted 04-07-2013 01:40 PM
Snipe happens when the end of the board farthest from the cutters is lower than it should be. Infeed or outfeed. If you’re sniping at the trailing end of the board, then the leading end has dropped too low by the time the trailing end is exiting the cutters. If you’re sniping at the leading end, then the trailing end is too low as you start your feed.
View Bill White's profile
Bill White
4853 posts in 3864 days
#5 posted 04-07-2013 02:09 PM
I have the DW 733 adjusted right, but I always lift the trailing end on infeed and lift the leading end on outfeed. Just a habit, but it works for me.
Bill
-- bill@magraphics.us
View Monte Pittman's profile
Monte Pittman
28157 posts in 2242 days
#6 posted 04-07-2013 02:14 PM
+1 again for nitewaljer
-- Mother Nature created it, I just assemble it.
View HorizontalMike's profile
HorizontalMike
7747 posts in 2818 days
#7 posted 04-07-2013 02:19 PM
Tootch,
Here is the infeed/outfeed table I made that pretty much eliminates sniping. Do remember that the shorter the board, the greater the chance for sniping and I occasionally still will get some sniping. Staggering pieces side-to-side and slightly over-lapping also helps stop the snipe. Regardless of the length of the table, adjusting infeed and outfeed angles is an important step as Nightwalker points out.
For perspective do notice that the overall length of the combined table is ‘longer’ than the 8ft length of the base. I actually used this to plane my 3”x12”x90” workbench top halves successfully.
http://lumberjocks.com/projects/34959
View Jim Finn's profile
Jim Finn
2614 posts in 2825 days
#8 posted 04-07-2013 08:52 PM
I have a DeWalt planer and I did just what NiteWalker says. I adjusted the in-feed and out-feed tables up a bit until the snipe disappeared.
Tooch
#9 posted 04-07-2013 09:03 PM
Holy cow! thanks to all of yinz for these tips. I am a new member and this is my first post—I’m absolutely blown away by how many of you are willing to share ideas. Good to know I’m not alone!!
is there an adjustment on the machine itself to raise the infeed/outfeed table? I bought this used and the manual wasn’t part of the deal…
View pintodeluxe's profile
pintodeluxe
5565 posts in 2717 days
#10 posted 04-07-2013 09:48 PM
http://www.ridgid.com/assets/0c168dd3b5724414aefb2c4d2e40c5a8/r4330_555_eng.pdf
Manual for adjusting infeed/outfeed tables.
View patcollins's profile
patcollins
1658 posts in 2769 days
#11 posted 04-07-2013 11:12 PM
Yinz, you must be from Picksburgh
Tooch
#12 posted 04-07-2013 11:23 PM
hoping somebody would pick up on that… n’at :-)
Tooch
#13 posted 04-07-2013 11:31 PM
pintodeluxe thanks for the link!
View gfadvm's profile
gfadvm
14940 posts in 2594 days
#14 posted 04-08-2013 02:26 AM
I too tilt the tables up quite a bit but if I’m planing a piece that absolutely can’t have any snipe, I use a follow board the same thickness. A short piece of pine is all it takes.
