How many power tools can I use on one 220 Volt outlet?
Forum topic by jaybellisle posted 04-07-2013 04:17 AM 2491 views 0 times favorited 17 replies Add to Favorites Watch
View jaybellisle's profile
jaybellisle
10 posts in 1872 days
04-07-2013 04:17 AM
Hey guys I have a G1023ZX 5 HP 10’’ tablesaw that runs off 220 and I am looking to get away from just a shop vac alone and wanting to upgrade to a 2HP dust collector and have only 1 220 outlet on the wall and was wondering if I could plug a dust collector into the same outlet as the tablesaw or do I have to have a separate plug for each machine. These would be the only machines that I have that run off 220. The dust collector I am looking to purchase is on sale right now and its a Grizzly 2hp G0548zp and is it a good purchase? Thanks for the information greatly appreciated.
-- jaybellisle@yahoo.com
17 replies so far
View Straightbowed's profile
Straightbowed
717 posts in 2262 days
#1 posted 04-07-2013 04:18 AM
1 millon 1 at a time
-- Stevo, work in tha city woodshop in the country
Straightbowed
#2 posted 04-07-2013 04:22 AM
you can rearrange your breaker box with some piggy back work and make room for another 25 amp or 220 breaker and then run 2 machines at once I don’t think I would run 2 machines off 1 breaker
Straightbowed
#3 posted 04-07-2013 04:26 AM
thats what I done to my break box it would be safer of course startup is where you draw the most power with seperate breakers you dont have to worry with overload but I am not an electricical eng. but that would be logical to me course I never went to college nor did i take pencil or paper to school for 5 years I fix things the way i want
Straightbowed
#4 posted 04-07-2013 04:28 AM
grizzly has good tools I have the 1023sl and it works hard and the 490 jointer they work well
View Nicky's profile
Nicky
695 posts in 4056 days
#5 posted 04-07-2013 04:36 AM
From http://www.engineeringtoolbox.com/elctrical-motor-full-load-current-d_1499.html
Your 5 hp motor will draw 28 amps
2hp dust collector will draw 12 amps
What size breaker do you have?
The figures above are full-load (continuous duty) numbers. Keep in mind that a motor starting-up will draw much more until its up to speed. I’d seek professional advice from an electrician. Some of the worries I would have include the size and length of the wires to your outlet.
-- Nicky
View AlaskaGuy's profile
AlaskaGuy
4042 posts in 2273 days
#6 posted 04-07-2013 04:37 AM
This looks like a one sided conversation :)
runswithscissors
2724 posts in 1989 days
#7 posted 04-07-2013 04:37 AM
I have my 220 Grizz DC on its own circuit breaker; everything else has to take its turn on the other breaker. I think it’s wise to separate them, as 5 hp. draws a lot of amps.
Straightbowed
#8 posted 04-07-2013 04:45 AM
all the electrician is goin to do is charge a bunch of money to piggy back some 15 amp breakers and put in a extra breaker this is very easy to do yourself the breakers just snap in you hook up the ground and the hot and thats it of course kill the power 1st
Straightbowed
#9 posted 04-07-2013 04:48 AM
have a good night sleep tite don’t let tha bed bugs bit where do you live Ill come and fix it up for you
Straightbowed
#10 posted 04-07-2013 04:54 AM
I sold a plow plane to a guy in alaska keep that cold wheather up there Ive had enough ready for some sunshine
AlaskaGuy
#11 posted 04-07-2013 05:09 AM
I sold a plow plane to a guy in Alaska keep that cold weather up there Ive had enough ready for some sunshine
Took this picture about 30 minutes ago. Enjoy.
View knotscott's profile
knotscott
7980 posts in 3339 days
#12 posted 04-07-2013 11:31 AM
I’m running a 3hp TS and a 2hp DC on the same 220v line without issue, but a 5hp TS motor would be too much on my circuit. Depending on the wire and the breaker, you’re probably either going to have to run a separate 220v line for the DC, or get a DC that’ll run on 110v.
4949 posts in 2457 days
#13 posted 04-07-2013 12:24 PM
You will be way better off with 2 circuits, I would do everything possible to get set up that way.
View jimmyb's profile
jimmyb
185 posts in 1856 days
#14 posted 04-07-2013 02:18 PM
Typically we need to run the circuit from the panel off one large breaker, say a 50 amp 220 volt breaker to a sub-panel. Then put two 20 amp 220 volt circuit breakers. Of course you need to adjust your amperage and wire sizes according to your needs. Keep in mind that besides the draw of your machines there is current loss due to distance.
So trying to run two machines off the same breaker could be a problem if there is a distance issue to the breaker panel; you start both at the same time or you put additional load on both. The sub-panel design will allow one machine to “pop” the breaker while the other continues running. Two machines on one breaker, both machines go down when the breaker pops.
-- Jim, Tinley Park, IL http://jbuda.net
jaybellisle
#15 posted 04-07-2013 04:48 PM
Well I think you guys made up my mind and I was leaning towards just putting in another breaker. This will not be are hard task once I get my son to crawl in the crawl space to run the wire which he is not to fond of but that’s what they are for lol. Thanks for all the information guys and I cant wait until I can get some real dust collection in my shop.
