Modding a TS fence
Forum topic by jimig11 posted 04-06-2013 01:21 PM 1285 views 0 times favorited 30 replies Add to Favorites Watch
View jimig11's profile
jimig11
56 posts in 2023 days
04-06-2013 01:21 PM
Hi all,
So I picked up a craftex fence for wicked cheap, I am talking $30 with rails cheap. Never used all with original stickers. However its roughly 6 ” to long for my table, which is a problem because of the locking mechanism.
I am thinking though, if I remove the end cap from fence, take out tension rod, then put the fence into a miter box, use a hack saw to bring it down to length, shorten the tension rod and re-thread the end of it, it should work. So before I go cutting up a $350 fence anyone see a problem with that idea? oh BTW the fence is extruded aluminium.
30 replies so far
View knotscott's profile
knotscott
8122 posts in 3497 days
#1 posted 04-06-2013 02:28 PM
That’s the same fence that came on the Ridgid TS3650, and is fairly well regarded. It’s worth a lot more than $30…maybe $100-$150, and it’ll directly fit a lot saws (Emerson and TTI/Ryobi made Ridgid and Craftsman contractor saws) so you might want to consider whether or not you want to sacrifice that value.
View Lee Barker's profile
Lee Barker
2170 posts in 2972 days
#2 posted 04-06-2013 02:32 PM
I like knotscott’s angle on this….could you resell it and make enough to get an easily-mounted unit?
I think your plan is a workable one, but now is a good time to consider all the possibilities when you’re in the game this easily.
Kindly,
View casual1carpenter's profile
casual1carpenter
354 posts in 2597 days
#3 posted 04-06-2013 05:19 PM
I’m having a moment of brain fart here so you might have to excuse me…. but. Is there any reason why you could not extend the distance between the rails with spacers. It might take a bit to figure out but you should be able to use it on this saw and still retain it’s value and usability on a larger unit.
jimig11
#4 posted 04-06-2013 11:08 PM
Ok, sorry guys been at work all day, antsy to get home and post replies, so as for selling it, I would be lucky to get $150, when i first started perusing Kijiji looking for an upgrade a guy posted an Excalibur fence for $120. It’s still up for sale. So in my area used TS fences don’t sell to fast. That was my 1st thought to. Then after realizing the time it would take to sell as well as a replacement starting at $200+ tax my mind moved to modding the fence.
No, no brain fart there, good question, as far as I can see I am not able to do that because of the mounting configuration and gap. See the mounting bolts are T-bolts that sit in a track in the rail, attach to your table with nuts, gap is 6”. Any ideas?
View distrbd's profile
distrbd
2252 posts in 2568 days
#5 posted 04-06-2013 11:43 PM
Without close up pictures it will be hard to quite understand why you have to cut it.try to find a way so it stays intact .
I almost bought that Excalibur fence from that seller in Toronto (Oakville) but decided against it and instead I bought a Beisemeyer fence which incidentally was also too big for my saw ,I managed to install it without cutting it down.
-- Ken from Ontario, Canada
jimig11
#6 posted 04-06-2013 11:51 PM
Funny you should say that, I am just charging my phone now so I can take some close ups. That guy is a clown, $120 or OBO I offer $100 and he sends me a nasty email back so i am kind of glad to hear you did not buy it. In about 45 min i will post close ups of everything I am working with, how much you pay for the bies? Rolls Royce of fences..
distrbd
#7 posted 04-07-2013 12:08 AM
That guy also didn’t want to budge from $120 ,I didn’t understand the point of putting “OBO” in any ad if the price is firm! he also wanted $25 gas money to meet me in GTA,I finally told him NO thank you.
The Beisemeyer was $250 but what a fence,it literary changed my pos saw in to a great saw.
jimig11
#8 posted 04-07-2013 03:58 AM
A closer look at the problem.
casual1carpenter
#9 posted 04-07-2013 04:24 AM
Are the bolts special, perhaps longer bolts could be used along with some dimensionally stable material to fill the (6”) gap. Is there a chance to use additional bolts? Depending on how much weight you ask that “table extension” to carry there might be some stretching or deflection with four bolts over that length of run.
runswithscissors
2823 posts in 2146 days
#10 posted 04-07-2013 04:30 AM
If the fence is aluminum, you don’t need to hacksaw it. Your chopsaw with a woodcutting blade will work fine. Squirt WD40 on the blade before cutting, which will help keep the al from sticking to the teeth. Won’t hurt your blade at all. Just cut slowly, and be sure the blade is up to speed before engaging in the metal.
View EEngineer's profile
EEngineer
1113 posts in 3735 days
#11 posted 04-07-2013 04:58 AM
Ahhh, I see your problem. This fence is designed for a 27” deep table. Yours is 20-21”?? So you want to shorten the fence, not the guide rails.
As far as the fence goes, I believe the main body of the fence is a standard extrusion. If it is that easily replaced, I wouldn’t feel bad about shortening the fence!
knotscott
#12 posted 04-07-2013 11:32 AM
How about adding an extension to the back of the saw, and mount the rear rail to that?
Here’s an example that actually extends the front and the back:
jimig11
#13 posted 04-07-2013 11:47 AM
F* I sold my chop saw last week. As far as making an extension goes, that would be my 1st choice, I just do not have the means to achieve that. That is, I am a total amateur and do not know how to go about it. My thoughts get stuck again on how do I mount the rail with those dang t bolts?
Also, extrusion is easy to get? If so, where can i get it? I would rather just buy the right length piece of extrusion and just move parts across, keeping original fence utilizable down the road.
View Craftsman70's profile
Craftsman70
244 posts in 2246 days
#14 posted 04-07-2013 12:14 PM
Can you post a pic of the back of the fence, including the threaded rod? Im wondering if there is a chance you can move the end piece that tighten on the rail without cutting the fence. Maybe it could move in 6 inches and just keep moving down the threaded rod.
jimig11
#15 posted 04-07-2013 02:11 PM
No go on that, theres a solid plate on the end cap for the tension rod nut.
showing 1 through 15 of 30 replies
