Forum topic by newwoodbutcher | posted 04-05-2013 05:17 AM | 1932 views | 0 times favorited | 25 replies | ![]() |
I’m getting lathered up about getting a new band saw. I’ve got a 16” Grizzly I’ve been using happily for 15 years. Works “fine”. Under powered for resawing (1 1/2 HP) and only a 6” resaw capability. But a good cast iron heavy frame and wheels with upgraded guides. I do a fair amount of resawing these days making veneer. I’m thinking I want a 2 HP saw with a 10”-13” resaw capacity that I will dedicate to resawing while setting my old 16” up for scroll work only. I’ve considered a 3HP Laguna saw but really want to keep the cost under $1,000 and don’t care much about the throat capacity as it will be dedicated to resawing. I’ve been shopping for a used saw for a few months and can’t find a good deal with the power and resaw capability I need/want. Grizzly is having a spring sale that coincides with my desire to get a new toy. The G0513ANV 17” saw is on sale for $795 plus shipping. Looks like a great price point for my needs. My only question, is the cast aluminum wheels. I’m wondering does the mass of cast iron wheels create a momentum or performance factor that’s worth more $$$$? Would I be happy with this saw? Any recommendations? -- Ken |
25 replies so far
#1 posted 04-05-2013 05:31 AM |
Anytime you add mass to a flywheel it will give you some extra oomph but if a 1.5hp is underpowered for you then I can’t imagine a 2hp is going to make you happy. -- Rick M, http://thewoodknack.blogspot.com/ |
#2 posted 04-05-2013 08:40 AM |
I can’t agree with Rick, you’ll find there is a considerable difference between 1 1/2 & 2HP motors, providing it is a like for like motor of course. Also bear in mind, it is after all bandsaw, with the extra power even more noticeable when driving the thin blade. It’s more important that the wheels are balanced, you can of course do this yourself quite easily using small self adhesive magnets placed strategically on the wheel rim. (There is an abundance of info on the net on how to do this.) Good luck David -- No one plans to fail, they just, just fail to plan |
#3 posted 04-05-2013 05:32 PM |
I’ve resawed 6” on a 3/4 HP motor, and while it wasn’t fast, it worked. The advantage of cast iron wheels is stability, from what i understand. But I’m sure there’s enough mass in 17” cast aluminum wheels to be plenty stable. -- ian | "You can't stop what's coming. It ain't all waiting on you. That's vanity." |
#4 posted 04-05-2013 06:55 PM |
I’m arranging a setup similar to yours (one resaw and one detail) and have just ordered an 18” Rikon from my local Woodcraft at their sale price of $1050. Might be worth considering if it’s near enough to your budget. 2.5 HP, 12” resaw capacity, cast iron wheels. |
#5 posted 04-05-2013 07:53 PM |
Cast iron wheels, being heavier are able to maintain blade speed better, but if you feed too agressively, the speed will drop and you risk breaking the blade before doing any damage to the wheels whether they be CI or aluminum. |
#6 posted 04-06-2013 02:41 AM |
It’s either cast iron or bags of power, either one will keep you smiling, as the CI simply stores and smooths power till needed with lighter motors.. Change your pulley and move on up to 5000 SFPM and you’ll be real happy. Speed counts, big time. -- gene@toronto.ontario.canada : dovetail free since '53, critiques always welcome. |
#7 posted 04-06-2013 02:49 AM |
If you are actually serious about having a dedicated resaw, They run 3” wide blades. I don’t want to mess with your head, but my opinion is |
#8 posted 04-06-2013 05:05 PM |
The important thing when resawing is blade tension. A lightly tensioned blade will twist easily. The typical 14” BS can’t be tensioned enough for 1/2” blades unless you change the tension spring. Doing so, may distort the BS’s frame or cause blade breakage. A 3” blade will resaw nicely, but they need a lot of tension. Some people resaw successfully with 1/4” blades because it can be tensioned higher. The resaws that use 3” blades have a small throat (distance between the blade and the frame). That makes for a very rigid frame that can withstand a lot of tension. I remember seeing a new Ryobi resaw machine over 30 years ago that cost $500. I haven’t seen any since. |
#9 posted 04-06-2013 09:58 PM |
Woodcraft has their 18” 2 1/2 HP saw on sale for $1050. Cast iron wheels, blade release and 12” resaw capability. It looks like it meets my spec plus a half HP more. Any one have this saw? Comments? -- Ken |
#10 posted 04-08-2013 12:44 AM |
I’ve looked for old iron for a few months. No luck. When it comes to new it looks like the 18” Rikon meets my requirements. I can’t see any way (without a long patient wait) to get a wider blade and/or more HP machine within my budget of $1,000. Do any of you have this saw? what is your assessment of it? Is it a good buy for my needs and budget? -- Ken |
#11 posted 04-08-2013 12:55 AM |
I have it but I only got it this weekend and haven’t used it yet. I am getting my woodslicer blades this week and should have some use of it before next weekend if parenting duties permit me the shop time! |
#12 posted 04-08-2013 01:11 AM |
its logical to buy something that will last when I first started woodworking I purchased crapsman saws and I finally learned to take my time and buy good equipment the heavier the better now when I want to work I just push a button and Im ready to go so what Im sayin is go heavy so you wont be cussin later cause your tools wont cut the mustard -- Stevo, work in tha city woodshop in the country |
#13 posted 04-08-2013 02:47 AM |
Good advice! Straightbowed, I’ve got a few weeks left on the sale. If you do get the blades and get to play with your new toy, I’d love to hear about it. -- Ken |
#14 posted 04-08-2013 02:07 PM |
There are thousands of G0555’s out there with aluminum wheels and happy owners. In fact I had one, I Couldn’t resaw with it, so I bought an 18” Recon and Woodslicer blade. Still can’t resaw. I’m convinced the world did not intend for all of us to resaw. (The world would be over-run with re-sawers)(spelling?) I make rocking chairs, so it’s no big deal. p.s. Good luck Elizabeth. -- Jim from Doniphan |
#15 posted 04-08-2013 03:02 PM |
I’ve heard people refer to less than adequate tools as boat anchors. Actually a cheap lightweight tool does not make a good boat anchor. |
Forum | Topics |
Woodworking Skill Share
12026 |
Woodturning
2104 |
Woodcarving
431 |
Scrollsawing
340 |
Joinery
1369 |
Finishing
4901 |
6691 |
28039 |
CNC Woodworking
211 |
Hand Tools
5404 |
Jigs & Fixtures
1417 |
Wood & Lumber
6224 |
1387 |
Focus on the Workspace
2153 |
1185 |
Woodworking Trade & Swap
4754 |
LumberJocks.com Site Feedback
2200 |
Coffee Lounge
8842 |
