How to inlay a circle on a table top
Forum topic by AaronSoccerMan posted 04-04-2013 08:23 AM 4332 views 0 times favorited 5 replies Add to Favorites Watch
View AaronSoccerMan's profile
4 posts in 2059 days
04-04-2013 08:23 AM
Topic tags/keywords: jig coffee table inlay router soccer field
I am constructing a coffee table for my major furniture project at school. On the table top I plan to inlay a soccer field as decoration. I have done all the straight lines now I am just looking for the best way to cut out the centre circle and the “D” outside the 16metre box. I have used a 10mm router drill bit for all my cuts and the router has been plunged 10mm into the wood. The circle has to have a radius of 90mm so what would be the best way to do it? Any ideas appreciated!
5 replies so far
View Ken90712's profile
17553 posts in 3118 days
#1 posted 04-04-2013 10:39 AM
Nice work so far look great!
Well I have used my circle templates, if I’m correct 90mm = 3.543 inches. I use the bit from Whiteside for making the hole and insert. I did some butterfly inlays with the same type of template here.
They are other ways to do it as well but to me removes some of the possibility of a goof.
Good luck.
View scotsman9's profile
134 posts in 1818 days
#2 posted 04-04-2013 11:02 AM
I love your project. Here’s an idea for you; and the best part is, your pin set can be part of your design:
There are many ways to accomplish your task, this is just one way.
-- Just a man and his opinion.
View Milo's profile
869 posts in 3249 days
#3 posted 04-04-2013 12:37 PM
I agree with the router idea. I trim router would work well, you could set the bit for the extremely low depth you need to install the inlay (it probably something like 1/16” right?), then use the above jig to cut out the outer ring. You could then take of the jig and route out the rest of the circle with the router freehand.
Norma did something very similar when he made some nesting tables once. At least I think that was the episode. You might check that out. I think he cut out the recess for the inlay with a dremel freehand.
Check out this video I found, I think it’s just what you want. Jump to around the 13 minute mark.
Let us know!
-- Beer, Beer, Thank God for Beer. It's my way of keeping my mind fresh and clear...
View AandCstyle's profile
3000 posts in 2187 days
#4 posted 04-05-2013 12:34 AM
If you don’t want to make holes for the pin set, you can affix the template to your table with double stick tape.
-- Art
View shipwright's profile
7935 posts in 2728 days
#5 posted 04-05-2013 12:39 AM
Use an inlay bushing set.
They’re cheap and will give you perfect fits.
-- Paul M ..............If God wanted us to have fiberglass boats he would have given us fibreglass trees.
