Best table saw blade type for my useage
Forum topic by dschlic1 posted 04-03-2013 06:20 PM 2646 views 1 time favorited 10 replies Add to Favorites Watch
View dschlic1's profile
dschlic1
421 posts in 1937 days
04-03-2013 06:20 PM
Topic tags/keywords: question oak tablesaw
I am completing a restoration to a Craftsman contractor style table saw. I need to purchase a new blade for the saw and would like some recommendations on selecting a type of blade. The vast majority of my cuts will be in plywood, mostly Baltic birch or veneer grade. However I will be cutting some solid lumber both ripping and crosscut.
I would like to know which blade would be better: a combination style blade or go with a regular fine tooth finishing blade?
10 replies so far
View ShaneA's profile
ShaneA
6910 posts in 2566 days
#1 posted 04-03-2013 06:23 PM
If you are looking at just one blade. I would have to recommend a 40 tooth combo blade. However, for best results, a ply wood (high tooth count type blade) and a rip blade may be best, but cost a bit more and lead to have to change blades between cuts.
View Clint Searl's profile
Clint Searl
1533 posts in 2329 days
#2 posted 04-03-2013 06:26 PM
The Freud Fusion 8” Combo will be perfect for the work you describe.
View pintodeluxe's profile
pintodeluxe
5623 posts in 2781 days
#3 posted 04-03-2013 06:30 PM
I would strongly recommend a thin kerf blade for that saw. It makes a big difference in terms of cut quality, and ease of use. Tooth count is just a function of what work you are doing. IE: 24 tooth for ripping, 80 tooth for fine crosscutting, 30-50 tooth blades do a little bit of everything.
A high ATB blade will make cleaner cuts in sheet goods. A combo blade features flat ground teeth, as well as high ATB teeth for the best of both worlds.
A thin kerf combo blade with 30-50 teeth should do nicely.
Look at Freud brand for one (available at HD, and everywhere online).
View knotscott's profile
knotscott
7980 posts in 3343 days
#4 posted 04-03-2013 09:36 PM
The 60T Hi-ATB Infinity 010-060 is a terrific blade and should be ideal for your situation (one of my favorites).....very similar to the Forrest WWI. It’s got a reasonably high tooth count (60T) and a Hi-ATB grind for very low tear out in crosscuts and ply cuts, plus it’s got a slightly positive hook angle to help it rip reasonably efficiently in hardwoods up to ~ 5/4”. (It’s ~ $70) The only way to do better in plywood is to get an 80T Hi-ATB blade, but you’ll need a different blade for ripping in that case.
If you think your cuts will be more hardwoods than ply, something like the Infinity Super General of Freud Fusion 40T would be a good all around choice. It wouldn’t be a bad idea to pick up a 24T FTG TK rip blade if you plan to rip thicker materials.
Tips for picking saw blades
View nitrowood's profile
nitrowood
56 posts in 2133 days
#5 posted 04-03-2013 10:41 PM
Freud 1/8” kerf combonation blade. I have one on my craftsman and it does an excellent job on plywood and ripping oak. However I would reccomend putting a link belt on if you haven’t already. It makes a world of difference. I’ve also made an upgrade with a Vega fence.
-- Craig , Woodworking is what I love to do. Trucking is what I have to do.
View JamesT's profile
JamesT
102 posts in 1880 days
#6 posted 04-04-2013 12:45 AM
Contractor saw means 1-1/2HP, which means a thin kerf will be you’re best bet. Grizzly has a TK 40 tooth general purpose Porter Cable on sale for $9.95. Not the best blade in town but by far the best price for a respectable blade. Cat. T22428
-- Jim from Doniphan
View pendledad's profile
pendledad
190 posts in 2057 days
#7 posted 04-04-2013 02:34 AM
Infinity super general…
Here is a shot that shows how clean it cuts in plywood. I do not have a zero clearance insert either.
dschlic1
#8 posted 04-05-2013 05:07 PM
I decided to purchase a fine tooth plywood blade, in particular the Diablo D1080X. Initial cuts in Baltic birch plywood look great. They have the appearance of being sanded! If I run into problems ripping lumber, I will purchase a rip blade.
View Robb's profile
Robb
660 posts in 3902 days
#9 posted 04-15-2013 09:27 AM
I have a 1 1/2 HP Jet table saw, and use a 24t Freud blade for ripping. It was about $35, I think. It’s a worthwhile investment – if you only use it for ripping, it will last a long time, and it just flies through the cuts.
-- Robb
View jimmyb's profile
jimmyb
185 posts in 1860 days
#10 posted 04-15-2013 12:21 PM
Been very happy with my Diablo (Frued) D1050X from HD. 50 tooth combo blade.
Will purchase other blades as I need them. Just picked up a 80 tooth, Diablo, brand new, opened package, from garage sale for $8.50 :)
-- Jim, Tinley Park, IL http://jbuda.net
