Weird tablesaw cut problem
4.4K views 42 replies 27 participants last post by  wormil
#1 · (Edited by Moderator)
My 15 year old Delta contractor has developed a strange problem. Every so often when cutting through the middle of a board the blade will give a little wobble. It happens at regular intervals, maybe every 3 seconds. It's very obvious on my full kerf rip blade and it may be happening on my thin kerf combo blade but it's hard to tell.
If it is the blade, wouldn't it happen almost constantly? Unfortunately I don't have a dial indicator to check the blade but since it only happens once out of every couple hundred rotations it might be impossible to measure.
It's hard to describe and too subtle to photograph but you can hear it. Here is an exaggerated drawing to show what I mean. It might happen 3 times on a 4 foot cut.
#5 ·
like the others suggested my first guess would be the belt.
if you can HEAR it - then take the belt off, and power up the saw and LISTEN. if you can still hear it then it's the motor shaft bearings or the motor winding. if you can't hear it then it's most likely the belt (or the blade arbor). try replacing the belt and see if it clears it.
#6 ·
Does it do it without cutting? Something is making the blade resonate, try a different blade, if it still does it you have a belt prob or the arbor is bad. I had this happen to my Unisaw, it turned out to be the nut, it was threaded crooked and putting more pressure on one side of the blade. My wife was helping me rip some long stock once and kept moving the boards to the side, it heated up the blade so much that it was ruined and did the same thing you describe, has your blade gotten hot recently?
#11 ·
It only happens when cutting in the middle of a board, ripping or crosscut. When I say I can hear it, I mean I can hear the blade dig deeper into both side of the cut, sometimes causing a burn, everything else sounds normal. I cleaned the blade and checked all the extension tables for flush/level but it still happened.
It does not happen when: not cutting, cutting on the edge of a board, or taking light cuts. I inspected the belt recently and there is no fraying, hazing or bumps, it looks fine but I won't rule it out.
@PurpLev - Something is making the blade resonate
Yes, well put. Something is causing a momentary resonance when cutting inside a piece. I made a new zero clearance insert on the off chance that my factory insert (which I normally use with the rip blade) is bobbling and causing the wood to shift. I'm getting ready to go test it.
#13 ·
"@PurpLev - Something is making the blade resonate"
Yep, and I'm guessing it's HEAT. The deeper you cut into the wood, the hotter the blade gets. I think the heat is causing the blade to actually warp. And then as the blade slows it cools, making the blade stiffer again. Any chance you checked the blade for very small cracks? Heat would cause those to "open up", thereby pushing the blade out of true.
#14 ·
Heat would make sense except it was my first cut of the day, through 4' of 1/2" MDF so I can't imagine that was the problem. I installed a splitter hoping it would fix the problem but after switching to a new zero clearance insert and installing the splitter it only happened once in a 4' cut but it still happened. The blade isn't very used, freshly cleaned, is relatively sharp. I was just up under the saw yesterday and didn't see any problems. Tomorrow I'll switch to a full kerf combo blade and see if it still happens. If the other blades cut fine I'll send this one out for a sharpening/rebalancing.
#17 ·
You may have a blade spindle shaft bearing issue. Or possably a rear motor armature bearing.
This can cause weird blade runout as they load and unload. I hope I'm not being to technical, I'm not
familiar with your model but if your model is direct motor drove to the blade. then the magnetic field
in the motor can cause armature pulse when bearings [wheather bronze or roller] are worn.
#19 ·
Okay, it's just that blade, it's not dull, and feed rate makes no difference. It also makes a very high pitch noise which I didn't notice yesterday wearing hearing protection. So I'm going to contact Freud and see what they suggest before I plunk down $10 for sharpening/balancing.
#23 · (Edited by Moderator)
Matt, a Cabinet table saw is not appropriate or even necessary for every shop. If you had a lack of power problem, it wasn't because of the saw. There are numerous things that it could of been. The saw not plugged into a sufficient electrical circuit and or extension cord, pulleys not aligned, not using the correct blade for the job, a dull blade, a fence that is out of parallel, the tilt hand wheel lock not tightened, etc. I bought a new Delta Contractor's table saw with a 30" Unifence almost 20 years ago, it's been a great saw for my shop.
