squaring up table top
Forum topic by lateralus819 posted 04-03-2013 12:13 AM 1476 views 2 times favorited 15 replies Add to Favorites Watch
View lateralus819's profile
lateralus819
2241 posts in 2087 days
04-03-2013 12:13 AM
I’m almost on the home stretch with this thing and of course one more problem arises! Argh…
Anyways, I’ve glued up two panels roughly 24” wide each, and i want to glue them together, i noticed though, when dry fitting there is a gap in the middle but not the ends, i checked with a straight edge and they aren’t perfect square.
A jointer isn’t an option,
would mounting them to a known square piece of MDF suffice? I think it seems as my only option, i tried hand planing the two face to face but somehow that didn’t work either. Thanks.
15 replies so far
View Mark Davisson's profile
Mark Davisson
597 posts in 3515 days
#1 posted 04-03-2013 12:34 AM
You’re trying to glue the two panels face-to-face or edge-to-edge?
-- I'm selfless because it feels so good!
View bondogaposis's profile
bondogaposis
5086 posts in 2549 days
#2 posted 04-03-2013 12:37 AM
More info please, I can’t picture the problem and how the MDF comes in.
-- Bondo Gaposis
lateralus819
#3 posted 04-03-2013 01:03 AM
basically if the panels were standing on edge there they have a curve (albeit minor, just not suitable to glue another panel). I need to get a straight edge, it bows in the middle (of the edge not the panel.)
Basically if i stick my panels to a sheet of mdf that has a square edge, i can use the mdf to guide down the fence on a table saw and get a square edge on my panel.
lateralus819
#4 posted 04-03-2013 01:05 AM
Mark, edge to edge, but the edges aren’t perfectly flat, somehow some way…
I dont own a jointer so thats out of teh equation.
think of it as turn trying to glue two C’s together. a bit more drastic than what i have going on though.
Mark Davisson
#5 posted 04-03-2013 01:07 AM
I received an email newsletter last week from Woodworker’s Journal. It contained a link to a very interesting article that might help you. http://www.woodworkersjournal.com/resource/TablesawTechniques/Jointing/index.html
Once you have one good, straight edge, you can reference the other 3 off of that.
bondogaposis
#6 posted 04-03-2013 01:16 AM
I would get a straight edge and draw a line down each panel and hand plane to the line. Checking the fit as you go. How big a gap are we talking here? Once you get to w/in a 1/32” you should be able to spring them together w/ clamps.
-- Bondo Gaposis
bondogaposis
#7 posted 04-03-2013 01:16 AM
-- Bondo Gaposis
lateralus819
#8 posted 04-03-2013 01:18 AM
Wow thats an incredible technique to know and it makes perfect sense!
View OnlyJustME's profile
OnlyJustME
1562 posts in 2575 days
#9 posted 04-03-2013 01:18 AM
Mark you couldn’t have posted this a week ago before i jointed all that mahogany by hand? Great article and info. i’ll be using it in the future.
-- In the end, when your life flashes before your eyes, will you like what you see?
lateralus819
#10 posted 04-03-2013 01:19 AM
It’s maybe 1/16-3/32”. I SUCK with a hand plane, I’ll either do as that article said or mate it to a sheet of MDF and use that as my “straight edge/guide”
View kdc68's profile
kdc68
2691 posts in 2474 days
#11 posted 04-03-2013 01:29 AM
Well theres a thing called a spring joint when gluing edge to edge. Having a slight gap in the middle is fine because the principle of a spring joint is when you apply clamp pressure in the middle until the gap goes away, both the ends butt tightly together. That is if your gap is slight
Another option would be to place your boards face to face clamped together flush and “shoot” the edges with a plane. Planing both edges at once will make two mate perfectly together
I don’t understand the mdf thing either. But the ideas above might work for you if I understand the rest of your question
-- Measure "at least" twice and cut once
lateralus819
#12 posted 04-03-2013 09:41 AM
I’ve tried to plane two at once and it didn’t work..
lateralus819
#13 posted 04-03-2013 09:49 AM
View hotbyte's profile
hotbyte
991 posts in 3173 days
#14 posted 04-03-2013 11:04 AM
Sounds like you are wanting to use the MDF similar to using a taper jig to straighten edge of a wavy board?
Article on tablesaw jointing is pretty neat. Might need to try that!
Another option is router table with straight bit and outfeed fence offset from infeed fence like on a jointer.
kdc68
#15 posted 04-03-2013 11:05 AM
lateralus… I seen your photo above…. that would work with one of your boards. Then you’d have to do the set up again for the other board and hope that you reference it the same (square) as the first. Marks idea he sent in a link via Woodworkers Journal is a good technique. It’s a jig that you set up once and run as many boards as you have in your glue up. A big Plus is you could use this jig over and over again for this project and others you do in the future since you don’t have a jointer…good luck
