Help-- lift mech for a drum sander.
Forum topic by Mrmyke posted 04-02-2013 10:42 PM 1273 views 0 times favorited 6 replies Add to Favorites Watch
View Mrmyke's profile
Mrmyke
41 posts in 2267 days
04-02-2013 10:42 PM
I’m planning a drum sander to build and need some help.
For the lift I am planning on using 4 threaded rods 4 bushing. 4 sprockets.
Will a 1/2” threaded rod be enough?
Any suggestions would be greatly appreciated
Thanks
Mike
-- mike
View Marty5965's profile
Marty5965
158 posts in 2185 days
#1 posted 04-04-2013 01:27 AM
All the shop-built drum sanders I have seen have manual adjustment via the feed bed secured with hand operated lock nuts that ride in slots cut into the sides. Most have a single threaded rod in the center of the infeed side. The drum does not move (since it is linked to the motor by the belt).
-- Marty, Columbus, OH, learning every day....
View Cole Tallerman's profile
Cole Tallerman
392 posts in 2424 days
#2 posted 04-04-2013 02:36 AM
I used a $15 scissor jack from harbor freight which works great!
View crank49's profile
crank49
4032 posts in 3210 days
#3 posted 04-05-2013 12:43 AM
If you want to use threaded rod for lifting I would use something with 16 threads per inch. That way you know that one revolution is raising the table by 1/16 inch, or if you only lift one end with the rod, then 1/32 inch per revolution.
Marty5965
#4 posted 04-05-2013 02:13 AM
good idea Crank, I like it.
Mrmyke
#5 posted 04-07-2013 04:24 AM
That’s a wicked good idea. I never would of thought of that. Ill definitely incorporated the 16 thread/ inch.
-- mike
View Woodknack's profile
Woodknack
12465 posts in 2619 days
#6 posted 04-07-2013 06:39 AM
Not sure what you’re planning but the Shopsmith design uses a threaded rod/wedge combination that reportedly works extremely well.
http://plansnow.com/dn3078.html
