First joint
« back to Joinery forum
Forum topic by hiswillus posted 04-02-2013 08:46 PM 1112 views 0 times favorited 12 replies Add to Favorites Watch
View hiswillus's profile
hiswillus
70 posts in 1915 days
04-02-2013 08:46 PM
Looking to get some constructive feedback on my first joint. Haven’t glued it up yet just have them sitting together and wondering if this joint looks good enough for glue up. Let me know what you think.
12 replies so far
View distrbd's profile
distrbd
2252 posts in 2413 days
#1 posted 04-02-2013 08:53 PM
I never forget my first joint (lol.),seriously thou,yours looks alright but I would take a couple of more passes before gluing them.
-- Ken from Ontario, Canada
hiswillus
#2 posted 04-02-2013 09:01 PM
Is that due to the corners rounding in, or the length of the joint itself?
View BTimmons's profile
BTimmons
2303 posts in 2451 days
#3 posted 04-02-2013 09:11 PM
How did you make the joint, for one thing? Powered jointer, hand planes?
-- Brian Timmons - http://www.BigTWoodworks.com
View RGtools's profile
RGtools
3372 posts in 2621 days
#4 posted 04-02-2013 09:11 PM
Try to put the two pieces together and push on the end of one of them, if the top board pivots anywhere besides the end, you probably have some more work to do. The pivot point is the hump. A slight hollow is ok, just make sure you can close it with hand pressure and your joints will be flawless.
How are you jointing?
-- Make furniture that lasts as long as the tree - Ryan
hiswillus
#5 posted 04-02-2013 09:15 PM
Hand tool woodworker ;)
BTimmons
#6 posted 04-02-2013 09:47 PM
I can’t tell how thick those pieces are, but if it’s possible to clamp them both in a vise and run a jointer plane over both edges at the same time, they should match up.
View Fettler's profile
Fettler
200 posts in 1963 days
#7 posted 04-02-2013 10:48 PM
Hard to see what’s going on from the photo, but it looks like a butt joint that’s flat except right at the very end? When working a hand plane there’s a tendency for concave corners at the beginning and end of a cut. The trick is to lift off the rear or front hand in the beginning and end of the cut respectively.
If you’re just going to cut off the ends, or If that seam will be hidden, your good to go. Otherwise a couple more passes should do the trick. I built an end table last year that had a seam like this but didn’t really care because it was on the inside of the table. A couple times I’ve gotten a board perfectly flat then dropped it on the ground which rounded a corner.
I would advise against trying to fix this with clamping pressure. In my experience it will just open right up again.
-- --Rob, Seattle, WA
View Marcus's profile
Marcus
1163 posts in 1986 days
#8 posted 04-02-2013 11:16 PM
As others have said, its a bit hard to tell from the pictures (due to the area of focus and bokeh blur down the length of the board), but it doesnt look too bad from what we can see.
RGtools
#9 posted 04-03-2013 03:01 PM
One other thing to check.. and this looks good from the picture, but how flat is the face when you have the joint together? If it’s cupped due to the joint you can correct that by taking selective (partial width) passes with your plane. On a piece this narrow it’s not a big deal, but when you start building panels it’s a skill worth knowing.
117063 posts in 3543 days
#10 posted 04-03-2013 03:31 PM
It’s really rather simple if you don’t have gaps and you wood grain is pleasing to the eye and you clamp and glue properly you will have a good joint. The trick is to know how to determine all those things when your getting started .
Take a look at the pros works and see how it’s done guys like Charles Neil,Darrell Peart,Chuck Bender and many many more top notch woodworkers.This will at least give you the foundation of what good joinery looks like.
View Airspeed's profile
Airspeed
445 posts in 1868 days
#11 posted 04-03-2013 03:58 PM
When I saw “first joint” I thought you wanted advice on how to roll it!
-- http://smg.photobucket.com/albums/v655/aaronhero/
hiswillus
#12 posted 04-03-2013 05:05 PM
Really good feedback guys!! Thanks!
Sorry the picture wasn’t the best, but it’s the best I could do. I’m sure the rounded ends is just me being lazy on the end and the beginning and taking to much off. I’ll hit ‘er with a few more passes.
Thanks,
Jeff
