Need help designing table legs
Forum topic by JoShmoe posted 04-02-2013 08:37 AM 1513 views 0 times favorited 9 replies Add to Favorites Watch
View JoShmoe's profile
JoShmoe
15 posts in 2063 days
04-02-2013 08:37 AM
Topic tags/keywords: question joining
Hi All,
I recently picked up a HUGE conference table top (about 4’ x 14’). However – it did not come with legs & therefore I’m in the middle of trying to design some. My favorite idea so far is to create two “V” shaped legs and connect them at the bottom of the “V” to provide extra stability (see highlighted (red box) section of picture below). However, with my limited woodworking skill-set, I’m not sure of how to actually construct something like this. I would like to get some feedback on best construction practices to create something like this. Please keep in mind, the simpler the joins the better!
The other picture is my fall back plan of creating a basic frame and then putting 6 large legs on it.
Thank you!
~Jo
-- Joe
9 replies so far
View bannerpond1's profile
bannerpond1
397 posts in 1863 days
#1 posted 04-02-2013 11:39 AM
If you use the design with the V’s, you’re going to have feet on those every time someone sits there. The finish will be marred over and over and the wood will be rounded over on the edges. With such a long table, I think you need the legs midway to keep it from sagging. Or maybe put a spine down the length with one leg in the very middle. That would preclude someone in the very center of the table from bumping his knees as he sits.
-- --Dale Page
View bondogaposis's profile
bondogaposis
4682 posts in 2316 days
#2 posted 04-02-2013 01:36 PM
That leaves out plan A. Go with plan B, but use mortise and tenon joinery.
-- Bondo Gaposis
View DrDirt's profile
DrDirt
4423 posts in 3707 days
#3 posted 04-02-2013 02:11 PM
I like the V – but you will still need a center support on a 14 foot table or it will sag…or break when someone decides to stand on it.
(e.g. to hang a projector from the ceiling in the conference room :-) )
View higtron's profile
higtron
235 posts in 2642 days
#4 posted 04-02-2013 02:23 PM
I like plan B but, I would add an apron around perimiter locking the table top to the leg structure with figure 8 fastners or, after creating a slot in the top of apron add wooden buttons that engage the slot and, screw the leg structure to the top.
-- A friend will help you move, a good friend will help you move a body
JoShmoe
#5 posted 04-04-2013 05:17 PM
Thanks everyone for your ideas! After thinking about it some more, I think I’ll go with the following modified design:
It will have 6 table legs with supporting structure. Now I have to figure out what size table leg will look “natural” attached to such a huge table.
I’m hoping to start work on this in the next month or so – I will attempt to post pictures once it’s done.
-- Joe
View PhillipRCW's profile
PhillipRCW
462 posts in 1229 days
#6 posted 12-10-2014 04:07 PM
Did you ever finish this project? Interested in seeing how it turned out. I will be making a large conference table soon if all goes well. Considering the leg options myself too.
-- Phillip- Measure twice, cut onc.... Hey look, it's rustic.
JoShmoe
#7 posted 12-11-2014 02:14 PM
Like many projects – I completed it about 90% :-)
I built the legs and the table is now in use as our dining room table but I haven’t gotten around to staining them (yet). I thought I had some pictures on my PC but I can’t find them so I’ll have to take some more & upload them for you.
I ended up building a supporting frame under the table top that tied into two main supports (one on each end) with a bridging beam down the center for stability. Looks great and is low profile so we can get a lot of chairs around it.
I’ll try & post pictures by this weekend.
-- Joe
PhillipRCW
#8 posted 12-11-2014 02:18 PM
Awesome. Can’t wait to see it. I am going to be making some large dining/conference tables soon and I think I’m going to do an even mix of modern steel legs and more rustic wooden legs.
JoShmoe
#9 posted 12-12-2014 02:30 AM
Alright, here we go! Let me know if you have any questions – this is definitely rough but sturdy :-)
-- Joe
