Difference in Dado Blade and Box Joint Blades
Forum topic by TimH posted 10-01-2008 03:52 PM 1078 views 0 times favorited 2 replies Add to Favorites Watch
View TimH's profile
TimH
37 posts in 3681 days
10-01-2008 03:52 PM
I’ve been looking at dado blade sets and was wondering what is the difference in a regular dado blade set and a box joist set?
2 replies so far
View woodsmithshop's profile
woodsmithshop
1337 posts in 3694 days
#1 posted 10-01-2008 04:09 PM
I have both, the dado set can be adjusted to quite a range of widths, whereas the box joint set can only be adjusted in two widths, 1/4” and 3/8”, it makes for easier setup each time you setup for box joints, because there is no adjustment except to turn the blades around depending on what size box joint you want, if you get the dado set, you have a wider range of widths to choose from, although it has to be adjusted each time you use it.
-- Smitty!!!
View sIKE's profile
sIKE
1271 posts in 3903 days
#2 posted 10-01-2008 05:13 PM
My understanding is that the BJJ will make flat bottoms and not all dadoes will do that.
