TS fence rail tube thickness
Forum topic by Charlie posted 03-31-2013 03:42 PM 1329 views 0 times favorited 10 replies Add to Favorites Watch
View Charlie's profile
Charlie
1100 posts in 2191 days
03-31-2013 03:42 PM
I’ve been watching Craigslist for some 2 inch square tube to fabricate a one-piece front rail for my TS fence. Today I see a few pieces up, but they’re 14 gauge. Is that too thin to use as a front rail? (it’s just under 5/64 wall thickness).
I was thinking I’d need at least 1/8 inch if I’m going to drill and tap it for the mounting bolts.
Anyone ever used aluminum square tube? I would guess that’d need to be a bit thicker wall, but…. figured I’d ask. :)
10 replies so far
View ajosephg's profile
ajosephg
1880 posts in 3466 days
#1 posted 04-01-2013 12:28 AM
Would you like me to measure my Delta T2 tube next time I’m in my shop?
-- Joe
Charlie
#2 posted 04-01-2013 11:03 AM
yes please. :)
View 6t5Goat's profile
6t5Goat
71 posts in 2916 days
#3 posted 04-01-2013 11:44 AM
I used aluminum.. Mine is only 3/16th thick..
http://lumberjocks.com/projects/63705
ajosephg
#4 posted 04-06-2013 10:48 AM
Charlie – a bit of Old Timer’s Syndrome, I forgot to measure my T2 tube’s wall thickness.
It is 0.090 including the paint (appears to be powder coated, and is quite thick.)
-- Joe
Charlie
#5 posted 04-06-2013 10:54 AM
Thanks, Joe
View JamesT's profile
JamesT
102 posts in 1817 days
#6 posted 04-06-2013 01:57 PM
Charlie,
1/8 X 2X2 steel will make a good fence. Should be able to find it at any metal supply. Check with a local welder on where to buy in your area. There is a five part video on youtube on making a table saw fence.
Google: How to make a table saw fence.
-- Jim from Doniphan
Charlie
#7 posted 04-06-2013 02:38 PM
Jim…. fence RAIL… not the fence itself :)
The stock fence on the Steel City isn’t a great fence, but it’s an ok fence. It locks into position and doesn’t deflect. However the front fence rail is a split rail system and I’ve never been able to get it to line up exactly. It’s very close. But when I get the fence to where it’s straddling the split, I notice the difference. And usually if I’m working on smaller pieces, a small error is magnified because it is a larger percentage of a given dimension.
Either that or I’m just anal. :)
JamesT
#8 posted 04-06-2013 06:44 PM
Sorry about that. I should have said 1/8X2X2 would make a good tube. I guess I don’t understand what you’re trying to do. Most rails are 1/4” 2X2 angle with the tube mounted on it. The youtube video also shows how to make rails.
View MrRon's profile
MrRon
4630 posts in 3148 days
#9 posted 04-06-2013 07:49 PM
The thickness of the rail on my Biesemeyer fence measures .081”.
Charlie
#10 posted 04-06-2013 08:35 PM
Jim, no apology please. I probably wasn’t clear.
The angle that’s bolted to the front of the table saw is one piece. The 2×2 fence rail that bolts to the angle is 2 pieces. I want to replace that 2-piece front rail with a 1-piece rail. So I need another piece of 2×2 stock and my question here is simply, what wall thickness should that 2×2 rail tube be.
