What to do to preserve this piece of walnut? Beeswax as a filler?
Forum topic by Jacob posted 03-31-2013 04:52 AM 946 views 0 times favorited 3 replies Add to Favorites Watch
View Jacob's profile
Jacob
85 posts in 2243 days
03-31-2013 04:52 AM
Topic tags/keywords: walnut
Picked this up today. Wondering what would work to deal with the center crack/checking. I would like to be able to use it for presentation for food, like cheese and crackers etc… would filling the cracks and checks with beeswax be a good idea? I’m not planing to use it as a cutting board tho.
I really want to try and keep the patina and overall used and abused look.
-- https://knotty-dawg-woodworks.myshopify.com/
3 replies so far
View Hammerthumb's profile
Hammerthumb
2836 posts in 1940 days
#1 posted 03-31-2013 05:11 AM
Maybe tape off around the cracks and fill with epoxy. Remove tape and lightly sand. Then burnish with beeswax mixed with mixed with mineral spirits. Maybe try and find a piece of wood of the same species to make a sample to make sure this is the look you are after.
-- Paul, Las Vegas
View Loren's profile
10260 posts in 3612 days
#2 posted 03-31-2013 06:03 AM
Cut a 3” ring out of the center. Fill.
View chopper1973's profile
chopper1973
4 posts in 1850 days
#3 posted 03-31-2013 07:02 AM
Sand the underside, collect the sanding dust and then mix with a small amount of pva glue. When mixed together use as a filler. Lightly sand smooth when dry, then use a danish oil to finish ( if you are using it for food).
