Spray Finishing Woes
Forum topic by Matt Przybylski posted 03-30-2013 10:39 PM 894 views 0 times favorited 4 replies Add to Favorites Watch
View Matt Przybylski's profile
Matt Przybylski
546 posts in 2372 days
03-30-2013 10:39 PM
Topic tags/keywords: earlex 5500 spray finish spraying poly
So, I have an Earlex 5500 and I’m spraying General Finished water based poly (gloss white). I’ve sprayed this before with what I thought was success but it was on a VERY small project. Well today I am spraying a much larger project and I’m spraying it in the basement. I put up some thin plastic paper on the walls and tarp on the ground. It’s obviously not air tight but I thought, for the most part, it would be decent enough. I went to spray and here are my issues:
1) I don’t know if I’m not dialing in the gun properly or what, but because the turbine pushes air through the gun and out the nozzle at all times, I feel like I’m getting A LOT of overspray. I can see the white mist getting pushed out and onto the plastic. I had set the gun to basically “closed” from the front nozzle end and from the rear where you adjust the amount of paint and i only opened each relatively slightly and I’m using the round spray pattern as I’m spraying baby gates which have thin spindles so I thought it made sense.
2) There is a layer of white dust EVERYWHERE in my basement now. It settled VERY quickly and I’m going to have a ton of cleanup to do after I’m done spraying. How do I prevent this further aside from the obvious, spraying in a dedicated booth or outside.
Any insight as to how these issues are dealt with normally would be greatly appreciated. Spraying is relatively painless but if I have to deal with these issues each time I spray indoors I’m going to have to switch over to brushing as this is not ideal for my situation…
-- Matt, Arizona, http://www.reintroducing.com
View AandCstyle's profile
AandCstyle
3050 posts in 2251 days
#1 posted 03-30-2013 11:18 PM
Generally, people use a good exhaust fan to pull the over spray out of the room. Another option is to make a portable, folding 3 walled structure with a partial roof and a fan centered in the center wall. Set it up in your garage with the garage door open. Put a furnace filter in front of the fan to keep the spray off the fan blades. Jeff Jewitt, and probably others, has described this arrangement in one of his books IIRC.
-- Art
Matt Przybylski
#2 posted 03-30-2013 11:23 PM
Art, I do have his book and saw the setup but didn’t get a chance to do it for this project. Is there a particular type of filter I need? I know they have different MIRV ratings etc but which would be best for this application? The cheap 4 pack so it can be easily replaced without costing too much? But then there is the question of that being enough to keep the paint off the blades…
AandCstyle
#3 posted 03-30-2013 11:58 PM
Matt, I use furnace filters that come in a 3 pack. I don’t recall the brand but they are nothing special. The reason is that the spray will clog the filter, so I use cheap ones and replace them often. I used 2 filters initially, but didn’t think I was getting enough draw with a 24” window box fan, so now I only use 1 filter at a time. If the fan dies I am not too concerned because it was only about $20 at the borg maybe 4 years ago.
-- Art
Matt Przybylski
#4 posted 03-31-2013 02:48 AM
Thank you Art, I’ll give it a shot next time I’m spraying. I’m also going to construct the booth that Jeff jewitt describes in his book for next time as well.
