air pressure regulator?
Forum topic by Belg1960 posted 03-30-2013 01:30 PM 1543 views 0 times favorited 9 replies Add to Favorites Watch
View Belg1960's profile
Belg1960
1068 posts in 3063 days
03-30-2013 01:30 PM
Topic tags/keywords: question
Good morning, I need to buy one of these for some airbrush type spraying. The recommended pressure is between 40-60 (latex paint) I would like to install this onto my standard compressor an old 30 gallon single stage unit. I’m looking for water trapping but I don’t need the lubrication feature as some of the things I will be spraying can’t oil mixed in them. Any input on a decent but not ridiculously priced unit would be very much appreciated.
-- ***Pat*** Rookie woodworker looking for an education!!!
9 replies so far
View Stephenw's profile
Stephenw
273 posts in 2383 days
#1 posted 03-30-2013 01:37 PM
A Husky regulator from Home Depot works great and flows plenty of air…
Husky 3/8" pressure regulator
The filter…
Husky 3/8" standard poly bowl filter
View plantek's profile
plantek
312 posts in 2797 days
#2 posted 03-30-2013 09:07 PM
I was just going to recommend the same as stephenw.
I have that on my compressor.
You can get it at HomeDepot
-- If you want it and it's within reason... It's on it's way!
View gfadvm's profile
gfadvm
14940 posts in 2688 days
#3 posted 03-31-2013 01:38 AM
I have both of those units that Stephenw recommended. The pressure regulator works great but the filter/water trap does NOT remove the water from the air well at all. Not sure what would work better.
View Dallas's profile
Dallas
3599 posts in 2485 days
#4 posted 03-31-2013 01:46 AM
Try a Watts inline desiccant air dryer.
gfadvm
#5 posted 03-31-2013 02:37 AM
Dallas- Is that air drier something that I can afford?
Belg1960
#6 posted 03-31-2013 12:38 PM
Guys, thanks for the replies.
Dallas, All I seem to be finding is pdf files for the Watts filters. Could you perhaps give me a link where to buy them?
Dallas
#7 posted 03-31-2013 12:51 PM
Andy, They aren’t very expensive. I believe there are some models under $20.
Pat Go down to your local welding supply or name brand air supply distributor.
View BennyG's profile
BennyG
15 posts in 1898 days
#8 posted 04-01-2013 05:01 PM
Hello all, thought I would add my 2 cents. I sold automotive paint and supplies for some time back in the early 90’s. One of the most important concepts in automotive paint is to have clean, dry air. Here is a little info that is important to know and a trick that will help.
When the compressed air leaves your tank, the water in it is still in vapor form (due to tempreture and the high pressure) and will stay in that way for about 25 feet down the line. So to make your water trap effective take an air hose around 25 feet long and connect it to the compressor. Next, loop it round and round, I just loop mine around the handle on my compressor, you could also loop and hang it on a hook in the wall. After this, connect the water trap, I have mine elevated a little above the compressor. This will be where you connect your tools with your regular air hose. The 25 foot or so of air hose gives the air time to cool down and the water to condense back into droplets. You will find that your water trap will actually trap water like it is supposed to. BennyG
-- "Dear Lord, when I die, please let my wife have enough sense to sell my tools for their true value and not for what I told her I paid."
gfadvm
#9 posted 04-02-2013 01:43 AM
Thanks Benny, can’t wait to try that tip as I hate water in my finish!
