Refurbishing Question on a Panel Gauge
« back to Hand Tools forum
Forum topic by Dave posted 03-30-2013 04:02 AM 1562 views 0 times favorited 44 replies Add to Favorites Watch
View Dave's profile
Dave
11429 posts in 3042 days
03-30-2013 04:02 AM
Topic tags/keywords: question
I have come across a nice gauge. The plates are made of steel and the screws are brass.
My question is what do you guys use to break the corrosion between the steel and brass while they are attached to the wood body of the tool? Hopefully not damaging the wood.
I would like to try my best to save the screws and not have to tap them out.
44 replies so far
View Joe Lyddon's profile
Joe Lyddon
10323 posts in 4254 days
#1 posted 03-30-2013 04:38 AM
Some kind of penetrating oil?
Electrolysis… watched very carefully as to not overdo it…
... when it looks like it has done something, pull it, clean it off, oil it down, & try to get them out…
... if no luck, wash down with soap & water & try it some more… etc. (??)
... That’s what I would try… no guarantees…
What is it & how is it used?
View Dave's profile
Dave
#2 posted 03-30-2013 05:07 AM
Thanks Joe.
Its a panel gauge.
It works just like a marking gauge.
Just a lot bigger.
It is real handy when you need to mark a panel then rip it by hand. It will give you a great straight line.
Joe Lyddon
#3 posted 03-30-2013 05:24 AM
OK, so there is small CUTTER in there somewhere… Makes sense…
View boxcarmarty's profile
boxcarmarty
16741 posts in 2562 days
#4 posted 03-30-2013 11:16 AM
Maybe clean and oil the wood first to help protect it against whatever else???
-- My mind is like lighting, one brilliant flash, then its gone.....
boxcarmarty
#5 posted 03-30-2013 11:20 AM
Could steaming the wood help loosen the screw like heat on steal???
Perhaps not. I think dry wood would be best in this case. Anything would swell the wood and make the screw tighter…..
View DIYaholic's profile
DIYaholic
19709 posts in 2877 days
#6 posted 03-30-2013 11:21 AM
Dave,
Wouldn’t it be easier to leave it as is…..
& hang it in Marty’s Museum???
View paratrooper34's profile
paratrooper34
915 posts in 3154 days
#7 posted 03-30-2013 11:41 AM
I would try heating it up with a heat gun. They should come loose with heat.
-- Mike
View stefang's profile
stefang
16133 posts in 3536 days
#8 posted 03-30-2013 12:02 PM
Interesting problem Dave. I haven’t a clue what to do except for searching the net. I did find something that suggested placing plastic between the brass and steel parts to prevent corrosion, but nothing on getting stuff apart.
View Dave's profile
Dave
#9 posted 03-30-2013 12:39 PM
Thank you gentlemen. It looks like I have got a good one.
Two of you have suggested heat.
I thank you for your time and efforts.
You to Randy.
I will post results when I try.
View Brit's profile
Brit
7545 posts in 3045 days
#10 posted 03-30-2013 12:50 PM
Dave – nice find. I would apply some penetrating oil and let it sit for 24 hours, then take a metal rod about 6” long, rest one end on each screw and give the other end of the rod a couple of taps with a metal hammer. This works wonders at breaking the seal. When you do eventually try to loosen the screws, make sure the screwdriver is a good fit in the slot to reduce the risk of it camming out. You might need to clean the slots out first with your little pointy tool. Everyone has a littly pointy tool don’t they?
-- https://www.clickasnap.com/Andy61 - Andy - Old Chinese proverb says: "If you think something can't be done, don't interrupt man who is doing it."
View Brit's profile
Brit
#11 posted 03-30-2013 12:52 PM
By the way Dave, any chance you can post a photo that shows the shape of the handle. It looks interesting.
Smitty_Cabinetshop
15701 posts in 2820 days
#12 posted 03-30-2013 12:56 PM
I need to catch up on this one – Am I correct in thinking it doesn’t function at all, and that’s why you’re wanting to disassemble?
View Oldtool's profile
Oldtool
2736 posts in 2393 days
#13 posted 03-30-2013 01:46 PM
Dave,
First and foremost, I would not try to remove any screws that weren’t necessary, to avoid any possible damage to the gauge not required for restoration. That means the wear plate, and adjustment screw plate. These can be polished up in place.
As for the scribe screw (assuming there is one, not shown in the photos) and the width adjustment screw, I would take great care to remove these without imposing any forces that could impart any damage, by proceeding as follows:
Very carefully use a sharp device like a large carpet needle to scratch all around the base of the screw in an attempt to remove the rust attached to the screw & plate junction, hopefully to create a small void or opening into which penetrating oil can be puddled. Then, as with soldering copper pipe, apply heat to draw the oil into the hidden threads.
This heat needs to be controlled, obviously, so I would use an electric soldering iron applied to the head of the screw. I would use a low wattage iron, maybe something like a cheep 30 watt iron.
This may do the trick, maybe not, but it won’t do any additional damage to the scribe.
Good luck, post the final results
Oldtool
-- "I am a firm believer in the people. If given the truth, they can be depended upon to meet any national crisis. The point is to bring them the real facts." - Abraham Lincoln
View sikrap's profile
sikrap
1121 posts in 3561 days
#14 posted 03-30-2013 09:19 PM
I would use Kroil. I have found Kroil will free rusted nuts/bolts when products like PB Blaster, 3 in 1 oil and others won’t have any affect.
-- Dave, Colonie, NY
View Don W's profile
Don W
19014 posts in 2769 days
#15 posted 03-30-2013 10:13 PM
and either an impact driver or a screw drive with some solid taps as you turn it.
showing 1 through 15 of 44 replies
