Is there a such thing as a 220 volt extension cord?
Forum topic by Beginningwoodworker posted 03-30-2013 12:55 AM 36904 views 0 times favorited 43 replies Add to Favorites Watch
Beginningwoodworker
13347 posts in 3542 days
03-30-2013 12:55 AM
Is there a such thing as a 100ft 220 volt extension cord? and would it work in my dryer plug? To run my 3hp Unisaw.
43 replies so far
View GT350's profile
GT350
361 posts in 1850 days
#1 posted 03-30-2013 01:00 AM
I have never seen a long extension cord made with 220v plugs on it. You can take a regular cord and put 220v cord caps on it. I would get a little larger gauge than the minimum size though.
Mike
View Built2Last's profile
Built2Last
234 posts in 3346 days
#2 posted 03-30-2013 01:01 AM
Usually best to make your own. Buy the male and female dryer ends and 100’ of 10-2 with ground wire. or you can just use the female end and wire it into your breaker box.
View RonInOhio's profile
RonInOhio
721 posts in 2733 days
#3 posted 03-30-2013 01:04 AM
I’m not aware of any over 12’ but I have heard of people running 220 well pumps
with cords as long as 100 feet. It depends on the wire gauge of your 30 amp circuit and
the gauge of your extension cord and the motor size on the Unisaw.
I know someone who said he could run a 100 ft. 220 extension cord and stay within limits
as long as the wire diameter on the extension cord was 8 gauge.
Of course, I’m not an expert. Just passing along what I heard.
View RogerC's profile
RogerC
51 posts in 2218 days
#4 posted 03-30-2013 01:05 AM
you can put whatever plug on the end of a cord that you want. At this Length and power requirment I would say you would need a GOOD 12AWG cord. Not just the cheapest peice of shit out there. I’m sure you could buy a 220v cord. Or I’d just goto an electrical supplier and buy 100’ of 12-3 cord and ask for a male and female 220v cord cap
RogerC
#5 posted 03-30-2013 01:08 AM
Depending on how much that motor actually draws you may want a 10-3 cord
Beginningwoodworker
#6 posted 03-30-2013 01:11 AM
Could I just buy a 220 volt cord pre made?
View lew's profile
lew
11887 posts in 3624 days
#7 posted 03-30-2013 01:19 AM
+1 for Roger. 100 feet- 10/3 w ground. Buy the plug and receptacle- it will be cheaper to make your own.
woodbutcherbynight
3729 posts in 2278 days
#8 posted 03-30-2013 01:24 AM
Why do feel you need a 100’ long 220 volt extension cord? No power to shop? Jobsite use?? Many here know a great deal about electrical and might be to help with any of the above.
View RockyTopScott's profile
RockyTopScott
1186 posts in 3347 days
#9 posted 03-30-2013 01:25 AM
Why not 10/2? This is what I use.
-- “When you want to help people, you tell them the truth. When you want to help yourself, you tell them what they want to hear.” ― Thomas Sowell
View AandCstyle's profile
AandCstyle
2945 posts in 2126 days
#10 posted 03-30-2013 01:42 AM
Curious, apparently you didn’t like the answers you got on another site, so asked the question here and are getting the same answers. Maybe you should ask the same question again on another site. lol
-- Art
View Dallas's profile
Dallas
3599 posts in 2356 days
#11 posted 03-30-2013 01:48 AM
50 amp RV cords are generally made from 6/3 SJOO. They come in 25’, 35’, 50’ and 100’ lengths.
Just be aware that you’ll be paying a premium. I have a brand new 35’ and it was $215.
View doyoulikegumwood's profile
doyoulikegumwood
384 posts in 3861 days
#12 posted 03-30-2013 02:12 AM
10/2 will not work you nee 2 hots a neutral and a ground. I would go with 8/3 personal NEC calls for 10/3 for runs up to 150 feet. this will be an extension cord so you want to factor in the run from the panel to the outlet and the cord from the tool as well. 10/2 no longer meets NEC standerds. im a fan of twist lock conector for the ends. just be aware the is not going to be cheap no mater witch way you go rv cords are a poor choice for it would be over kill and 10/3 or 10/4 cable is about 250 bucks for 150 foot roll. while i would say 8/3 is the way to go i think you would fine with 10/3 or 4 if you find your under 150. btw i keep saying 10/3 or 4 because cord which is what you want is often sold as 10/4 rather then 10/3. ultimately you need the cord to have 4 wires.
-- I buy tools so i can make more money,so ican buy more tools so I can work more, to make more money, so I can buy more tool, so I can work more
RockyTopScott
#13 posted 03-30-2013 02:22 AM
If the plug from the saw has 3 wires including the ground, why do you need the neutral?
woodbutcherbynight
#14 posted 03-30-2013 02:25 AM
For the same reason your airplane seat has a life preserver under it, regulations… (laughing)
doyoulikegumwood
#15 posted 03-30-2013 02:28 AM
thanks wood butcher stole the words right out of my mouth.
showing 1 through 15 of 43 replies
