Need a blade recommendation for finger joints - 1/8"
Forum topic by JustJoe posted 03-30-2013 12:02 AM 976 views 0 times favorited 6 replies Add to Favorites Watch
View JustJoe's profile
JustJoe
1554 posts in 1946 days
03-30-2013 12:02 AM
I want to make some boxes with small finger joints – the thickness of a regular sawblade, not 1/4” or fatter so the dado set is out of the question. Looking at all my blades it seems that none of them leave a perfectly flat bottom. I guess some of it is due to the set of the teeth but the amount seems to vary greatly blade to blade. My think-kerf blades are very pronounced – they leave almost a V-shaped bottom. I’ve got an older 1/8” rip blade that I can just make out the name Freud on – it is close but still leaves a bit of a V.
So are there any regular blades out there that leave a flat bottom? I’ve got a Sears, Lowes, Home Depot fairly close, or could drive an hour+ to the woodcraft or Horror Freight. Doesn’t have to be an expensive blade – I’ve got ways of dealing with tear-out and the cuts themselves will only be about 3/16” deep. All I need is a flat-bottomed kerf.
thanks
Joe
EDIT: If no such beast exists, does anyone have that HF saw blade sharpener and can it be used to flatten the top profile of the teeth?
-- This Ad Space For Sale! Your Ad Here! Reach a targeted audience! Affordable Rates, easy financing! Contact an ad represenative today at JustJoe's Advertising Consortium.
View TheDane's profile
TheDane
5367 posts in 3570 days
#1 posted 03-30-2013 12:08 AM
Joe … Freud makes flat-top rip blades in both thin and regular kerf. I have one (packed away somewhere in storage) that I used to make finer joints … did a great job.
View knotscott's profile
knotscott
7876 posts in 3283 days
#2 posted 03-30-2013 12:19 AM
Gerry’s got it. You need a blade with a flat top grind (FTG)....no other grind will leave a truly flat bottom. Those are mainly found on dedicated 18T to 24T rip blades. There are 1/8” full kerf and 3/32” thin kerf versions available. Freud, CMT, Infinity, Delta Industrial, Amana, Ridge Carbide, and others have them available.
View pintodeluxe's profile
pintodeluxe
5568 posts in 2721 days
#3 posted 03-30-2013 12:24 AM
Freud 50 tooth combo blade is what I use for finger joints. Full kerf with every 3rd tooth flat ground.
View AlbertaJim's profile
AlbertaJim
47 posts in 2336 days
#4 posted 03-30-2013 12:35 AM
I have not measured them but also the outside cutters on a dado set have flat tops & I think are 1/8”.
-- My Boss was a carpenter
JustJoe
#5 posted 03-30-2013 12:54 AM
Thanks for all the quick responses. Knowing what term to search for made it a bit easier. I went through the Freud site and found four 10” ripping blades with a FTG. Amana had another three. I’ll take the list into town tomorrow and see if any of the box stores have them. If they don’t, I’ll look up in Tucson when I go up next Monday.
CMT only had them in the 8 and 12” sizes. I looked at the Infinity and the were a bit pricey. Since at least one of the stores sells Delta tools, I’ll see if I can find a chart of their blades just in case.
thanks again – you saved me a lot of googling.
Joe
View gfadvm's profile
gfadvm
14940 posts in 2597 days
#6 posted 03-30-2013 01:47 AM
Just another option: router table with 1/8” spiral bit.
