Wood Carvers- Sandpaper tricks?
Forum topic by cliffb posted 62 days ago 130 views 0 times favorited 4 replies Add to Favorites
View cliffb's profile
cliffb
8 posts in 79 days
62 days ago
Topic tags/keywords: question
Thanks to all those who welcomed this new guy to LJ. My wife is a carver, making varied things from Celtic love spoons to small animals and elves. She likes things sanded smoothly, doesn’t like “rustic” appearances. Getting sandpaper into small places wear her fingernails off pretty thoroughly. She uses wet/dry sandpaper rolled into little cylinders, sometimes uses the self-adhesive sandpaper that seems only available from Ace Hardware. they roll up nice and tight. But she still ends up with no fingernails at the end of a project. Any suggestions would be greatly appreciated.
-- I ain't lost. People are always tellin me where to go.........
6716 posts in 388 days
61 days ago
She could glue the paper to various sized sticks & dowell of the right shape.
View Joey's profile
Joey
229 posts in 352 days
61 days ago
i assume she is sanding the bowls. I make spoons too and have experimented with how to smooth the bowl of the spoon. After carving the bowl I use a combination of a rotary tool with a buffing pad and gooseneck scraper. using the scraper will smooth the wood enough that you can finish with a high grit sandpaper.
-- Joey, Magee, Ms http://woodnwaresms.com
View CoolDavion's profile
CoolDavion
143 posts in 361 days
61 days ago
Check out a hoby shop like a model train shop or this website http://www.micromark.com/ they specialize in small tools. regular emery boards from the walmart/target might help, depending on fine they are/you need.
cliffb
8 posts in 79 days
56 days ago
We do appreciate the suggestions, in fact my better half used the gooseneck scraper, liked it a lot, but it’s tough to hold the spoon still enough to do it properly. I tried to glue sandpaper to a 1/8 inch dowel, it don’t stick long enough to do the job. May try bamboo skewers and epoxy, then throw them away when done. Cheaper than dowels, fer sure. Needle files are getting close, I bought her a set of 6, but she likes SMOOTH finishes…. May try jeweler’s tools, next.
Bookmark And Share This Page
