FOG IN THE SHOP
Forum topic by Grumpy posted 62 days ago 282 views 0 times favorited 28 replies Add to Favorites
6716 posts in 388 days
62 days ago
Topic tags/keywords: safety glasses fog on glasses fogged up safety glasses question
Now the Sun is coming back down under so will the humidity with the heat.
One of the safety issues in the workshop is that nusiance fog that appears on the inside of the safety glasses.
Does anyone out there have any ideas on a safe chemical to use on the inside of the glasses.
I know divers spit on their goggles which works in water but not so well in the shop.
Back Pain
View DAN's profile
DAN
3496 posts in 519 days
62 days ago
try this link >grin< ... I ding-dong double-dog dare ya !
-- ..... art for lifes sake ... danwalters@lumberjocks.com
View fredf's profile
fredf
228 posts in 246 days
62 days ago
I’d bet that rain-x would work if you have that down under—tho am pretty sure it contains silicone so you would want to be careful not to spread it around the shop . . . an eyeglass place would have an anti fog compound too. might well contain silicone too, tho
-- Fred, Springfield, Ma
View BeechPilotBarry's profile
BeechPilotBarry
410 posts in 239 days
62 days ago
I’ve used lots of products, as this is a big problem when mountain biking. Think fogged glasses are a nuisance in the shop? Try hitting a wet log or rock in the trail, while riding a bicycle at night. <g>
In the long run, CLEAN glasses stay unfogged longer for me, as well as adjusting them so there is some airflow around the lenses. I’ve even drilled 1/16” holes along the bottom, above my cheek, for more airflow. Maybe some extra airflow in the shop may also help.
-- - Real men read directions
62 days ago
Thanks Dan. I missed that link should have done a search.
Fred I have some rain-x but not sure what it would do to my eyes.
Good tip there Barry. Some extra holes might work..
62 days ago
I saw a face shield at the mower shop recently. It had a see through gauze mask. Might be worth a try.
View bbqking's profile
bbqking
277 posts in 260 days
62 days ago
Grumpy- Just set your thermostat to 72 degrees like I do. Believe me that will take care of any fogging problems. Come on, you only go around once, and you can’t take it with you. Yes, that means installing an air conditioner. You won’t believe how much more shop time you’ll accumulate. You can hang meat in my shop. As always, bbqKing. And yes , I still know what time it is In Sydney. (Time for an Ale.)
-- bbqKing, Lawrenceville
62 days ago
King, it’s a bit early for a beer, does not mix with machinery. Air conditioned shop?, next you will be saying I should have electricity. LOL
bbqking
61 days ago
If you are still running on that coal fired steam equipment, that could have something to do with that fogging. BBqKing.
61 days ago
What’s coal?. LOL
View DAN's profile
DAN
61 days ago
CLICK TO ENLARGE
View lew's profile
lew
1750 posts in 292 days
61 days ago
Grumpy,
As a scuba diver, we switched from spit to dish washing liquid. Rub a little on the inside and rinse it off with water. Don’t know if it will on shop glasses, but it won’t cost anything to try. Besides, it was easier than rubbing the diving mask with a raw cut potato.
Lew
View northwoodsman's profile
northwoodsman
53 posts in 283 days
61 days ago
I don’t know if you have any ski shops around, but they may sell an item called “Cat Crap”. It’s an anti fog agent for lenses and goggles. It works very well. It really isn’t what the name implies, but then again maybe it is? I’m sworn to secrecy.
-- NorthWoodsMan
View DAN's profile
DAN
61 days ago
61 days ago
Thanks everybody for your suggestions. I am sure there will be an answer among those ideas.
View DAN's profile
DAN
60 days ago
SAFETY FIRST
View mrtrim's profile
mrtrim
1548 posts in 417 days
60 days ago
are you sure its fog , or maybe grog ? lol
View cpt_hammer's profile
cpt_hammer
80 posts in 349 days
60 days ago
As another fellow diver, we always used toothpaste(non gell type). Take a small dab and run it over the lenses then rinse off with some water. Works great for several days/dives.
2081 posts in 558 days
60 days ago
I’m an old school diver so I’m not up on these latest remedies.
Most tooth pastes contain sodium lauryl or laureth sulfate as a foaming surfactant.
They often have glycerine or similar glycols as well to make them feel smooth to the tongue.
It’s hard to say which or both may be helping our divers see better.
I’m pretty sure it ain’t the fluoride. <g>
View EAGLE's profile
EAGLE
53 posts in 249 days
60 days ago
I have never had a problem with fogging glasses but I think I once read that if you rub the glasses with a used softener sheet from the dryer it should help. please let me know if it works because if it doesn’t I would like to know so i don’t recommend it again. Good Luck
BeechPilotBarry
60 days ago
I think the toothpaste, dish detergent, etc… improve vision because the glasses are CLEAN!
But that’s just me…
59 days ago
Thanks jocks, there should be a remedy amongst all that.
Trim, no grog in the shop. Does not mix with sawdust too well.
Dan, those goggles suit you.
View DAN's profile
DAN
58 days ago
PhotobucketPhotobucket
View DAN's profile
DAN
58 days ago
wall street safety googles
View GaryCN's profile
GaryCN
83 posts in 471 days
58 days ago
Rain X Anti Fog
-- Quando Omni Flunkus Moritati
57 days ago
View DAN's profile
DAN
56 days ago
View HokieMojo's profile
HokieMojo
414 posts in 265 days
56 days ago
the other two suggestions is anti fog spray for hockey visors and for paintball masks. Both have worked well for those uses and would probably help you too. Not too expensive either.
View DAN's profile
DAN
56 days ago
Bookmark And Share This Page
