(It was) Urgent Capacitor Help (but now it's sorted)
Forum topic by 404 - Not Found posted 03-29-2013 12:52 PM 1533 views 1 time favorited 18 replies Add to Favorites Watch
404 - Not Found
2544 posts in 2872 days
03-29-2013 12:52 PM
Thought I could smell burning yesterday, went to turn on dust extractor this morning to find the capacitor is fried. There’s all stuff coming out of it.
Sourced a replacement but it won’t ship for a fortnight, I need the dust extractor more than the bandsaw at the moment, I’m thinking can I borrow the one off the bandsaw for a couple of weeks to get me by?
Burnt out one 12uf – has runtimes for 420Vac and 470Vac
One in the bandsaw 10uf – has runtime for 450Vac
Will it work or will I just wreck the one in the bandsaw? Does anyone know? I’m really in a pickle without the DE
Thanks in advance for any guidance you can give me
18 replies so far
View JoeinGa's profile
JoeinGa
7733 posts in 1910 days
#1 posted 03-29-2013 01:01 PM
Maybe you could match it up at Radio Shack?
View waho6o9's profile
waho6o9
8099 posts in 2480 days
#2 posted 03-29-2013 01:02 PM
I’d use the one from the band saw and see no problem with using it.
I’m not an electrician, but was told that if you’re with in 10% of the micro fared rating
you’d be OK. Don’t know if it’s true or not but it hasn’t caused any problems for me
as of yet.
View wunderaa's profile
wunderaa
248 posts in 2106 days
#3 posted 03-29-2013 01:24 PM
Swap the other one and you’ll be just fine. These starting caps are readily available if you look around.
Starting cap
Good luck!
View tenontim's profile
tenontim
2131 posts in 3647 days
#4 posted 03-29-2013 01:38 PM
If you have a local air conditioning service company in the area, they would most likely have one.
404 - Not Found
#5 posted 03-29-2013 01:44 PM
BACK UP AND RUNNING!
Thanks guys, swapped out the one from the BS, just wanted to check before snipping any wires.
Thanks again
View crank49's profile
crank49
4029 posts in 2874 days
#6 posted 03-29-2013 02:44 PM
I’m a little late to the party, as usual, but glad you got it back running.
The main thing you have to be careful with capacitors is the voltage rating.
It’s nice to match the uf rating within plus/minus 20%, but the voltage needs to be at least as high or greater.
A mis-matched uf rating might not work as well but it won’t fry.
Too low on the voltage and it might not pass the smoke test.
404 - Not Found
#7 posted 03-29-2013 06:48 PM
Thanks Michael, that’s good to know if another one burns out.
View Grandpa's profile
Grandpa
3259 posts in 2578 days
#8 posted 03-30-2013 02:21 AM
I had the same thought as tenontim. go to an A/C shop. They have most of them.
oops!! I just looked and you might be in an area where they don’t use A/C…....hhhhmmmm
woodbutcherbynight
3937 posts in 2312 days
#9 posted 03-30-2013 02:29 AM
Regrettably having a spare on hand will make you mad as they have a odd tendency to be “dead” after years of storage. They cannot explain it, will refute it, but they know it is true in the end. My Grandfather had a box of them in his shop when he died, all about 10 years old. We chekced them all and only one of 34 actually checked good with a uF meter. Go figure..
View kizerpea's profile
kizerpea
774 posts in 2270 days
#10 posted 03-30-2013 02:08 PM
any HVAC supply house should have them..
-- IF YOUR NOT MAKING DUST...YOU ARE COLLECTING IT! SOUTH CAROLINA.
View HorizontalMike's profile
HorizontalMike
7747 posts in 2817 days
#11 posted 03-30-2013 02:40 PM
woodbutcherbynight,
The electrolyte dries up and the capacitors fail, over time. That is likely why all those ‘spares’ were bad.
http://en.wikipedia.org/wiki/Electrolytic_capacitor
View nwbusa's profile
nwbusa
1021 posts in 2189 days
#12 posted 03-30-2013 03:29 PM
Leaky caps. Been there, done that.
-- John, BC, Canada
View MrRon's profile
MrRon
4627 posts in 3146 days
#13 posted 03-30-2013 09:13 PM
Renners, Are you posting from Britain, or are you English?
View redryder's profile
redryder
2393 posts in 3005 days
#14 posted 03-30-2013 09:36 PM
There’s an expression you don’t hear often. Nicely said…....................
-- mike...............
woodbutcherbynight
#15 posted 03-31-2013 12:43 AM
HorizontalMike, thanks for the reason I had wondered the why of it. My Father gave me a Jet 1014 mini lathe and after a few uses the capacitor gave out. He used it maybe 2 times in the last 7 years??
