Joewhite just brought up a good thought...
Forum topic by DKV posted 03-29-2013 04:32 AM 1939 views 0 times favorited 45 replies Add to Favorites Watch
View DKV's profile
DKV
3940 posts in 2379 days
03-29-2013 04:32 AM
and it got me to thinking. How many Jocks out there can adjust a sled or miter gauge to within .001” and why would you want to? When it comes to woodworking I do not think .001” (that’s better than 1/512”) would matter in any of the projects that I have seen on this site. In fact why would it matter in any wood project. In fact I would be really interested to know what type wood project even requires that kind of rocket science tolerances. Going to the moon or ISS…I understand. Building a chair or table or box…I don’t understand.
-- This is a Troll Free zone.
45 replies so far
woodbutcherbynight
3759 posts in 2283 days
#1 posted 03-29-2013 04:37 AM
I have no idea, but enjoyed the question. Some guys sweep, clean, and in a recent post admit to dusting and waxing a shop. Why? Have no idea, if I catch anyone attempting to do so in my shop I will shoot, shoot again, reload then ask the questions…........ (laughing)
View jumbojack's profile
jumbojack
1673 posts in 2499 days
#2 posted 03-29-2013 05:15 AM
Within .001 not in this hacks shop. The OP however was out .005. For most work that is OK, Im not going to do the math on what .005 over 24” equals, but I know it will show up in a miter like say a picture frame. Three of the miters will come together pretty well and look OK. It is that pesky fourth corner. Lots of glue, a little saw dust and heavy clamp might be able to cover .005, but not .006.
View Rick_M's profile
Rick_M
10832 posts in 2255 days
#3 posted 03-29-2013 06:12 AM
Miters are about the only time I get really anal about tolerances but even then there are plenty of tricks to make it work out right. My philosophy, which has served me well, is it’s more important to look right than be right (obviously this doesn’t work for everything but it works in woodworking and printing).
-- http://thewoodknack.blogspot.com/
View NiteWalker's profile
NiteWalker
2736 posts in 2451 days
#4 posted 03-29-2013 11:11 AM
I try to get as square as possible because of cumulative error. If I cut pieces for a box, and the ends aren’t square, the box will wobble once assembled and require sanding/hand planing to level it out.
404 - Not Found
2544 posts in 2844 days
#5 posted 03-29-2013 12:16 PM
If I can see a chink of daylight between square and cut, then it’s wrong. If I can’t see a chink of daylight between square and cut, then it’s right. Simple.
I have never done a project that has to withstand re-entry into the Earth’s atmosphere, so chinks have worked for me thus far.
View JoeinGa's profile
JoeinGa
7732 posts in 1882 days
#6 posted 03-29-2013 12:31 PM
”Close enough only counts in horseshoes and hand grenades”
Who said that? I dunno, prolly some famous person. But it seems to apply here :-)
View Miles King's profile
Miles King
28 posts in 2567 days
#7 posted 03-29-2013 12:32 PM
I agree with renners. For miter gauges or sleds to check for square I make a cut then flip one piece and press the two end pieces together. If there isn’t a gap then it is square enough for me. Is that within 0.001? I don’t know. All that I know is that’s the best that I can do and so far I haven’t had an accumulative error problem with miter or angle cuts that I couldn’t correct. Additionally I use the widest board I can, sheets good are best and for cross cut sleds I use the five cut method that helps to magnify any error.
-- Miles
View madts's profile (online now)
madts
1832 posts in 2214 days
#8 posted 03-29-2013 01:24 PM
Good enough for government work. What is that tolerance? 1”?
-- Thor and Odin are still the greatest of Gods.
View tenontim's profile
tenontim
2131 posts in 3619 days
#9 posted 03-29-2013 01:26 PM
File to fit; paint to hide.
View unbob's profile
unbob
801 posts in 1778 days
#10 posted 03-29-2013 02:16 PM
NiteWalker hit on what I try to reduce “acumlative error”.
I started out using hand tools only, but went with machines to speed up projects, and reduce the hand work because of past injury.
The better I can dial in the machines, the less handwork needed, better for me anyway.
View DKV's profile
DKV
#11 posted 03-29-2013 06:40 PM
Human hair and miter joints…
“Flaxen hair is the finest, from 1/1500 to 1/500 of an inch in diameter … and black hair is the coarsest, from 1/450 to 1/140 of an inch.”
Are all your miter joints blond?
View SCOTSMAN's profile
SCOTSMAN
5845 posts in 3460 days
#12 posted 03-29-2013 06:51 PM
DKV you are correct I have been saying this for years too many adjustments to machinery fine tolerences not needed in my book you are correct. Alistair
I always work myself to the nearest half inch and that works fine with the aid of car body filler.LOL
View MrRon's profile
MrRon
4566 posts in 3118 days
#13 posted 03-29-2013 08:44 PM
There is a difference between “cutting” wood and “machining” wood. When working with hard woods like Maple, much closer tolerances are needed, like in dovetails. True, it is hard to hold to tolerances measured in thousands, but the closer you can get, the better will be the fit. Besides, there are some on this forum who were brought up in the metalworking disiplines (me included) and find it easy to maintain close tolerances.
You will also find that woodworking machines made for the manufacturing trades are very precise. When they mill a 2×4, every piece comes out a perfect 1.5×3.5. What it ends up after it leaves the mill depends on the environmental conditions. That puts the difference between home and commercial machines in perspective.
Cutting wood is like studying for a school exam. If you shoot for a C, you will end up with a D, but if you shoot for an A, then a B is perfectly acceptable. Close enough is never good enough in my book.
unbob
#14 posted 03-29-2013 10:27 PM
Ha Ha! Machinist myself.
When they get old, they start working wood. One sure sign is, they usually only buy machines that weigh at least 1000lbs!
Since they have to constantly adjust metal working machines, it only natural to fine tune the wood machines.
Always looking for a better machined surface finish, and fit.
View Cosmicsniper's profile
Cosmicsniper
2202 posts in 3033 days
#15 posted 03-29-2013 10:30 PM
Because I can.
-- jay, www.allaboutastro.com
showing 1 through 15 of 45 replies
